Nextbook NEXT7P12-8G Camera Replacement
    1. Nextbook NEXT7P12-8G Camera Replacement, Camera: step 1, image 1 of 1
      • Use the plastic opening tool to pry apart the front and back covers of the Nextbook
      • Continue prying until the front and back covers are completely separated. Use the suction cup if necessary to pull apart
      • We recommend using an extra plastic opening tool to maintain your opening
      Ask FixBot
    2. Nextbook NEXT7P12-8G Camera Replacement: step 2, image 1 of 1
      • Once the front and back covers have been separated, set the back cover down and examine the interior of the Nextbook
      • Remove the various pieces of masking tape
      Ask FixBot
    3. Nextbook NEXT7P12-8G Camera Replacement: step 3, image 1 of 1
      • Carefully peel the battery pack off, starting from the outer edges
      • It is held down by an adhesive going diagonally across the back
      • Removing the battery will allow you to access the screws holding the chip in place
      Ask FixBot
    4. Nextbook NEXT7P12-8G Camera Replacement: step 4, image 1 of 1
      • Use a 4.0 bit screwdriver to remove the screws from the chip
      Ask FixBot
    5. Nextbook NEXT7P12-8G Camera Replacement: step 5, image 1 of 1
      • Remove the entire chip by severing small adhesive strips along the edges and pulling the chip away from the frame
      • Carefully peel away the black tape with copper detail that is holding the chip to the device
      Ask FixBot
    6. Nextbook NEXT7P12-8G Camera Replacement: step 6, image 1 of 1
      • Locate the camera
      • The camera will be a small black square directly behind the camera lens visible on the front side of the Nextbook
      • Pry the camera out of the front cover with the plastic opening tool
      Ask FixBot
    7. Nextbook NEXT7P12-8G Camera Replacement: step 7, image 1 of 1
      • Replace with a spare camera piece
      Ask FixBot
Grace Cho
3 Reputation
1 Guide authored
Ohio State, Team 2-2, Garvin Fall 2015 Member of Ohio State, Team 2-2, Garvin Fall 2015
OSU-GARVIN-F15S2G2
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 1,067
