Nextbook Flexx 10 Back Cover Replacement
    1. Nextbook Flexx 10 Back Cover Replacement, Back Cover: step 1, image 1 of 2 Nextbook Flexx 10 Back Cover Replacement, Back Cover: step 1, image 2 of 2
      • To begin, turn off the power to the device and remove the screen from the keyboard.
      • Open the 2-in-1, and hold the screen.
      • Press the silver button at the top of the keyboard.
      • When the screen lifts up, gently lift the screen away from the keyboard.
      Ask FixBot
    2. Nextbook Flexx 10 Back Cover Replacement: step 2, image 1 of 3 Nextbook Flexx 10 Back Cover Replacement: step 2, image 2 of 3 Nextbook Flexx 10 Back Cover Replacement: step 2, image 3 of 3
      • You may use your fingers, or a spudger. Be careful not to break your cover OR your fingernail. Removing the cover requires good judgement.
      • The goal is to separate the black from the silver. Start in a corner, or a flat edge -- whichever works best for you. Remember to not use too much force.
      • Once you start the initial separation, keep going until you free one edge. The goal now is to free three edges of the rectangle.
      • If your progress stops on one side of the rectangle, go to the other side and try there.
      Ask FixBot
    3. Nextbook Flexx 10 Back Cover Replacement: step 3, image 1 of 2 Nextbook Flexx 10 Back Cover Replacement: step 3, image 2 of 2
      • Gently pull the back cover from the screen assembly.
      • Keep the plastic cover close. It's great for holding screws!
      • When putting the cover back on, press firmly around to outside edge with the screen facing down on a flat, debris-free surface.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 18
Past 30 Days: 42
All Time: 1,871
