Nextbook Ares 8" Tablet Teardown
Views: 7.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
102
All Time:
7,808
Comments: 9
1 comment on steps, 8 guide comments.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 12
12 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Nextbook Ares 8" Tablet Teardown, Remove back cover: step 1, image 1 of 1
      • Wedge between the frame and back cover with an isesamo and separate all of the retaining clips
      Ask FixBot
    2. Nextbook Ares 8" Tablet Teardown, Disconnect battery: step 2, image 1 of 2 Nextbook Ares 8" Tablet Teardown, Disconnect battery: step 2, image 2 of 2
      • The connector slides out towards the outside of the device, and mine was pretty sticky so be careful.
      Ask FixBot
    3. Nextbook Ares 8" Tablet Teardown, Disconnect screen assembly: step 3, image 1 of 3 Nextbook Ares 8" Tablet Teardown, Disconnect screen assembly: step 3, image 2 of 3 Nextbook Ares 8" Tablet Teardown, Disconnect screen assembly: step 3, image 3 of 3
      • Disconnect the LCD ribbon cable from the top and bottom of the battery. It is unnecessary to peel it off of the battery.
      • Disconnect the digi cable from the top right of the back of the device.
      Ask FixBot
    4. Nextbook Ares 8" Tablet Teardown, Disconnect periphery flexes: step 4, image 1 of 2 Nextbook Ares 8" Tablet Teardown, Disconnect periphery flexes: step 4, image 2 of 2
      • Disconnect the camera flex
      • Disconnect the power/volume/home flex
      Ask FixBot
    5. Nextbook Ares 8" Tablet Teardown, Remove the speaker assembly: step 5, image 1 of 1
      • Remove the 5 speaker assembly screws and pry off the assembly
      • At this point you can also lightly pull the battery away from the back of the LCD. There isn't much adhesive holding it in place.
      Ask FixBot
    6. Nextbook Ares 8" Tablet Teardown, Remove the motherboard: step 6, image 1 of 2 Nextbook Ares 8" Tablet Teardown, Remove the motherboard: step 6, image 2 of 2
      • Remove the 5 motherboard screws and gently separate it from the back of the lcd.
      • At this point, the only thing left should be the display assembly
      Ask FixBot
    7. Nextbook Ares 8" Tablet Teardown, Remove the LCD: step 7, image 1 of 2 Nextbook Ares 8" Tablet Teardown, Remove the LCD: step 7, image 2 of 2
      • Remove the 6 LCD screws and brackets
      • Gently separate the LCD from the frame
      Ask FixBot
    8. Nextbook Ares 8" Tablet Teardown, Separate the glass from the frame: step 8, image 1 of 3 Nextbook Ares 8" Tablet Teardown, Separate the glass from the frame: step 8, image 2 of 3 Nextbook Ares 8" Tablet Teardown, Separate the glass from the frame: step 8, image 3 of 3
      • Use a heat gun or hot plate to separate the digitzer and glass from the frame
      • Before heating the frame its a good idea to remove the camera from the frame so it's not damaged.
      Ask FixBot
    9. Nextbook Ares 8" Tablet Teardown, Complete!: step 9, image 1 of 1
      • Insert wisdom here.
      Ask FixBot
14 other people completed this guide.
Auburn Store
523 Reputation
1 Guide authored
8 Guide Comments
The screen is crack the screen is on when I hit the home button it won't work
Hilda Silva - Reply Share
I replaced screen and now screen won't light up
ruger32016 - Reply Share
How can u get the whole tablet fixed when the screen came off and everything is not their in its place any more???
Cupcake - Reply Share
my touch screen does’nt respond can it be replace and where could i get one and what is the price. Im from mauritius thk
Alphonse Tonio - Reply Share
My touch screen does’nt respond is this can be change and where can i get one and what the price i’m from Mauritius
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 102
All Time: 7,808
