Nextbook 8 Speaker Replacement
    1. Nextbook 8 Speaker Replacement, Battery: step 1, image 1 of 2 Nextbook 8 Speaker Replacement, Battery: step 1, image 2 of 2
      • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
      • Slide the tool along the edge to work the back cover off.
      • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
      Ask FixBot
    2. Nextbook 8 Speaker Replacement: step 2, image 1 of 2 Nextbook 8 Speaker Replacement: step 2, image 2 of 2
      • Remove the tape covering the motherboard.
      • Remove the silver tape holding the white ribbon cables to the battery.
      Ask FixBot
    3. Nextbook 8 Speaker Replacement: step 3, image 1 of 2 Nextbook 8 Speaker Replacement: step 3, image 2 of 2
      • Use a spudger to carefully disconnect the battery connector from the motherboard.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      Ask FixBot
    4. Nextbook 8 Speaker Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
      • Pull the ribbon cables out of the connectors with tweezers or two fingers.
      Ask FixBot
    5. Nextbook 8 Speaker Replacement: step 5, image 1 of 2 Nextbook 8 Speaker Replacement: step 5, image 2 of 2
      • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
      • The battery is very malleable, so do not try to pull it off all at once.
      Ask FixBot
    1. Nextbook 8 Speaker Replacement, Speaker: step 6, image 1 of 1
      • Use a small Phillips screwdriver to remove the 0.116 inch screw holding the red and black wires in place on the inside of the back cover.
      Ask FixBot
    2. Nextbook 8 Speaker Replacement: step 7, image 1 of 1
      • Remove the two 0.116 inch screws holding the speaker assembly in place.
      Ask FixBot
    3. Nextbook 8 Speaker Replacement: step 8, image 1 of 1
      • Carefully pry the speaker off of the back cover with a spudger.
      • Note: There is glue holding the speaker to the back cover, so it will take some work to get it off.
      Ask FixBot
    4. Nextbook 8 Speaker Replacement: step 9, image 1 of 1
      • Use a desoldering tool to remove the solder holding the red and black speaker wires to the motherboard.
      • If you do not have a desoldering tool, you can use a solder gun to remove the old solder.
      • Caution: Soldering guns get extremely hot.
      Ask FixBot
    5. Nextbook 8 Speaker Replacement: step 10, image 1 of 1
      • Use the soldering gun to solder the new speaker wires to the motherboard where the original wires were connected.
      • Make sure that you connect the red wire to the positive terminal on the right, and the black wire to the negative terminal on the left.
      Ask FixBot
Dylan Wiese
1,889 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 94
All Time: 1,774
