Up to 20% off select tools
Nextbook 8 Screen Replacement
Views: 25K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
104
All Time:
24,775
Comments: 7
6 comments on steps, 1 guide comment.
Go to guide comments
Completed: 21
21 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
You need a thin tool to get the back cover off. If a plastic opening tool is not available, a guitar pick works just fine. Use caution when removing the back cover and inside parts.
    1. Nextbook 8 Screen Replacement, Battery: step 1, image 1 of 2 Nextbook 8 Screen Replacement, Battery: step 1, image 2 of 2
      • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
      • Slide the tool along the edge to work the back cover off.
      • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
      Ask FixBot
    2. Nextbook 8 Screen Replacement: step 2, image 1 of 2 Nextbook 8 Screen Replacement: step 2, image 2 of 2
      • Remove the tape covering the motherboard.
      • Remove the silver tape holding the white ribbon cables to the battery.
      Ask FixBot
    3. Nextbook 8 Screen Replacement: step 3, image 1 of 2 Nextbook 8 Screen Replacement: step 3, image 2 of 2
      • Use a spudger to carefully disconnect the battery connector from the motherboard.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      Ask FixBot
    4. Nextbook 8 Screen Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
      • Pull the ribbon cables out of the connectors with tweezers or two fingers.
      Ask FixBot
    5. Nextbook 8 Screen Replacement: step 5, image 1 of 2 Nextbook 8 Screen Replacement: step 5, image 2 of 2
      • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
      • The battery is very malleable, so do not try to pull it off all at once.
      Ask FixBot
    1. Nextbook 8 Screen Replacement, Screen: step 6, image 1 of 1
      • Remove the silver and gold sticker at the bottom of the device.
      • Hold the brown circuit board down with your finger while you remove the sticker
      Ask FixBot
    2. Nextbook 8 Screen Replacement: step 7, image 1 of 2 Nextbook 8 Screen Replacement: step 7, image 2 of 2
      Buy
      • Use a spudger to lift up the black tabs on the three ZIF connectors.
      • Use ESD safe tweezers to pull the ribbon cables out of the three connectors.
      Ask FixBot
    3. Nextbook 8 Screen Replacement: step 8, image 1 of 2 Nextbook 8 Screen Replacement: step 8, image 2 of 2
      • Remove the 5 black screws on the motherboard.
      • Carefully lift the motherboard off of the device and remove.
      Ask FixBot
    4. Nextbook 8 Screen Replacement: step 9, image 1 of 2 Nextbook 8 Screen Replacement: step 9, image 2 of 2
      • Remove the two screws that hold the brackets in place.
      • Remove the two silver brackets that hold the screen in place.
      Ask FixBot
    5. Nextbook 8 Screen Replacement: step 10, image 1 of 2 Nextbook 8 Screen Replacement: step 10, image 2 of 2
      • Remove the one silver screw on the small green circuit board at the bottom of the device.
      • Set aside the small circuit board for now.
      Ask FixBot
    6. Nextbook 8 Screen Replacement: step 11, image 1 of 1
      • Remove the two silver screws from the bottom of the device.
      Ask FixBot
    7. Nextbook 8 Screen Replacement: step 12, image 1 of 3 Nextbook 8 Screen Replacement: step 12, image 2 of 3 Nextbook 8 Screen Replacement: step 12, image 3 of 3
      • With the device face down, use a spudger to lift the screen off of the glass from the right side.
      Ask FixBot
21 other people completed this guide.
Author
with
Dylan Wiese
1,889 Reputation
5 Guides authored
1 Guide Comment
where do I find the actual screen though
WiKiT Woo WoNKa - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 104
All Time: 24,775
