Up to 20% off select tools
Nextbook 8 Camera Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
82
All Time:
1,893
Comments: 6
6 comments on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
    1. Nextbook 8 Camera Replacement, Battery: step 1, image 1 of 2 Nextbook 8 Camera Replacement, Battery: step 1, image 2 of 2
      • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
      • Slide the tool along the edge to work the back cover off.
      • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
      Ask FixBot
    2. Nextbook 8 Camera Replacement: step 2, image 1 of 2 Nextbook 8 Camera Replacement: step 2, image 2 of 2
      • Remove the tape covering the motherboard.
      • Remove the silver tape holding the white ribbon cables to the battery.
      Ask FixBot
    3. Nextbook 8 Camera Replacement: step 3, image 1 of 2 Nextbook 8 Camera Replacement: step 3, image 2 of 2
      • Use a spudger to carefully disconnect the battery connector from the motherboard.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      Ask FixBot
    4. Nextbook 8 Camera Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
      • Pull the ribbon cables out of the connectors with tweezers or two fingers.
      Ask FixBot
    5. Nextbook 8 Camera Replacement: step 5, image 1 of 2 Nextbook 8 Camera Replacement: step 5, image 2 of 2
      • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
      • The battery is very malleable, so do not try to pull it off all at once.
      Ask FixBot
    1. Nextbook 8 Camera Replacement, Camera: step 6, image 1 of 1
      • Slowly pull up masking tape by pulling down from the top.
      • Be careful because both the front and rear cameras are attached to each other.
      Ask FixBot
    2. Nextbook 8 Camera Replacement: step 7, image 1 of 1
      • Peel the bottom part of the masking tape off to reveal the ribbon connector.
      Ask FixBot
    3. Nextbook 8 Camera Replacement: step 8, image 1 of 1
      • Pull both camera lenses out of the holes.
      Ask FixBot
    4. Nextbook 8 Camera Replacement: step 9, image 1 of 1
      • Use a spudger to disconnect the two camera lenses from the device.
      • Carefully lift the black connector to release the cameras.
      Ask FixBot
    5. Nextbook 8 Camera Replacement: step 10, image 1 of 1
      • Pull both camera lenses out of the ribbon connector.
      Ask FixBot
Author
with
Dylan Wiese
1,889 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 82
All Time: 1,893
