NextBook Ares 8 LCD Panel Replacement
    1. NextBook Ares 8 LCD Panel Replacement, Remove The Housing: step 1, image 1 of 1
      • Be careful around the middle of the device, you could puncture the battery.
      • Pry the back cover off with the jimmy, starting from the bottom, ending at the top.
      Ask FixBot
    2. NextBook Ares 8 LCD Panel Replacement, Removing Battery: step 2, image 1 of 3 NextBook Ares 8 LCD Panel Replacement, Removing Battery: step 2, image 2 of 3 NextBook Ares 8 LCD Panel Replacement, Removing Battery: step 2, image 3 of 3
      • Disconnect the battery.
      • Undo the LCD cable extender.
      • Lift up and remove battery.
      Ask FixBot
    3. NextBook Ares 8 LCD Panel Replacement, Goodbye Speaker!: step 3, image 1 of 2 NextBook Ares 8 LCD Panel Replacement, Goodbye Speaker!: step 3, image 2 of 2
      • Disconnect speaker, be careful to not break off the wires from the connector.
      • Next, remove the speaker from it's bracket.
      Ask FixBot
    4. NextBook Ares 8 LCD Panel Replacement, Disconnect Cables!: step 4, image 1 of 1
      • Disconnect all the flex cables.
      Ask FixBot
    5. NextBook Ares 8 LCD Panel Replacement, Remove Screws: step 5, image 1 of 2 NextBook Ares 8 LCD Panel Replacement, Remove Screws: step 5, image 2 of 2
      • Remove the black screws on the top and bottom of the device.
      Ask FixBot
    6. NextBook Ares 8 LCD Panel Replacement, Removing LCD Brackets: step 6, image 1 of 1
      • Unscrew the circled screws and remove the brackets. The brackets may be located in different places on your tablet.
      • Lift the LCD panel out of place and put in new one.
      Ask FixBot
CubicBuilder9
566 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 16
All Time: 227
