Community-Contributed Guide
Carefully insert a solid, flat object between the front and back of the case.
Move this object carefully between the housing parts to separate them.
Untie the front and back sides and place them on a smooth surface.
Flip up the two clamps that hold the flat cables up to release them.
Carefully pull out the flat cables.
Unplug the cable on the bottom of the tablet.
Turn the 3 small Phillips screws out of the board.
Using a spatula, remove the glue between the battery and the screen.
Take the board and the battery out of the case.
The screen can now be removed.
Repeat the steps in order to reassemble your device.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
