NexTime Wall Pad Clock Movement Replacement
    1. NexTime Wall Pad Clock Movement Replacement, Clock Movement: step 1, image 1 of 1
      • Place the clock face down.
      • Remove the battery.
      Ask FixBot
    2. NexTime Wall Pad Clock Movement Replacement: step 2, image 1 of 2 NexTime Wall Pad Clock Movement Replacement: step 2, image 2 of 2
      • Turn the brown gear clockwise until both the minute and hour hands align.
      Ask FixBot
    3. NexTime Wall Pad Clock Movement Replacement: step 3, image 1 of 2 NexTime Wall Pad Clock Movement Replacement: step 3, image 2 of 2
      • Use a pair of pliers to pull out the cap.
      Ask FixBot
    4. NexTime Wall Pad Clock Movement Replacement: step 4, image 1 of 2 NexTime Wall Pad Clock Movement Replacement: step 4, image 2 of 2
      • Pull out the minute hand using your fingers.
      Ask FixBot
    5. NexTime Wall Pad Clock Movement Replacement: step 5, image 1 of 2 NexTime Wall Pad Clock Movement Replacement: step 5, image 2 of 2
      • Pull out the hour hand using your fingers.
      Ask FixBot
    6. NexTime Wall Pad Clock Movement Replacement: step 6, image 1 of 3 NexTime Wall Pad Clock Movement Replacement: step 6, image 2 of 3 NexTime Wall Pad Clock Movement Replacement: step 6, image 3 of 3
      • Find the two ridges on the washer.
      • Use a pair of pliers to screw the washer out with a counter clockwise motion.
      • Use your fingers to remove the washer.
      Ask FixBot
    7. NexTime Wall Pad Clock Movement Replacement: step 7, image 1 of 1
      • Take out the clock movement mechanism and replace it.
      Ask FixBot
Leo Santos
145 Reputation
1 Guide authored
1 Guide Comment
what size to by the shaf nexime
john - Reply Share
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 101
All Time: 2,782
