Newport e500 Right Side Panel Disassembly
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
27
All Time:
241
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Medical Equipment Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Introduction
Go to step 1 ↓
In order to replace most other parts in the Newport e500, the removal of the right side panel is required. In order to perform this operation, a Philips screwdriver and torque wrench will be required. For more information refer to page 41 of the service manual.
Tools
    1. Newport e500 Right Side Panel Disassembly, Newport e500 Top Cover Disassembly: step 1, image 1 of 1
      • Place device so that the top cover is facing you.
      • Open the top cover.
      Ask FixBot
    2. Newport e500 Right Side Panel Disassembly: step 2, image 1 of 1
      • Remove the four hex nuts and lock washers (two at each hinge) that secure the cover to the hinges on the left side of the pneumatic box.
      Ask FixBot
    3. Newport e500 Right Side Panel Disassembly: step 3, image 1 of 1
      • Remove the cover and set aside. Retain hardware for re-assembly.
      Ask FixBot
    1. Newport e500 Right Side Panel Disassembly, Newport e500 Right Side Panel Disassembly: step 4, image 1 of 1
      • Carefully place the GDU on its left side.
      Ask FixBot
    2. Newport e500 Right Side Panel Disassembly: step 5, image 1 of 1
      • Remove the four screws and washers at the top edge of the right side panel.
      Ask FixBot
    3. Newport e500 Right Side Panel Disassembly: step 6, image 1 of 1
      • Remove the two screws and washers from the underside of the right side panel.
      Ask FixBot
    4. Newport e500 Right Side Panel Disassembly: step 7, image 1 of 1
      • Remove the right side panel. Retain hardware for re-assembly.
      Ask FixBot
Jeremy
589 Reputation
6 Guides authored
Cal Poly, Team S7-G16, Paton Spring 2020 Member of Cal Poly, Team S7-G16, Paton Spring 2020
CPSU-PATON-S20S7G16
3 Members
156 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 241
