Newport e500 Power Supply Disassembly
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Newport e500 Power Supply Disassembly, Newport e500 Top Cover Disassembly: step 1, image 1 of 1
    • Place device so that the top cover is facing you.
    • Open the top cover.
    Ask FixBot
  2. Newport e500 Power Supply Disassembly: step 2, image 1 of 1
    • Remove the four hex nuts and lock washers (two at each hinge) that secure the cover to the hinges on the left side of the pneumatic box.
    Ask FixBot
  3. Newport e500 Power Supply Disassembly: step 3, image 1 of 1
    • Remove the cover and set aside. Retain hardware for re-assembly.
    Ask FixBot
  4. Newport e500 Power Supply Disassembly, Newport e500 Left Side Panel Disassembly: step 4, image 1 of 1
    • Carefully place the GDU on its right side with the front of the GDU facing you.
    • Remove the three screws and washers at the top edge of the left side panel.
    Ask FixBot
  5. Newport e500 Power Supply Disassembly: step 5, image 1 of 1
    • Remove the two screws and washers from the underside of the left side panel.
    Ask FixBot
  6. Newport e500 Power Supply Disassembly: step 6, image 1 of 1
    • Remove the left side panel. Retain hardware for re-assembly.
    Ask FixBot
  7. Newport e500 Power Supply Disassembly, Newport e500 Right Side Panel Disassembly: step 7, image 1 of 1
    • Carefully place the GDU on its left side.
    Ask FixBot
  8. Newport e500 Power Supply Disassembly: step 8, image 1 of 1
    • Remove the four screws and washers at the top edge of the right side panel.
    Ask FixBot
  9. Newport e500 Power Supply Disassembly: step 9, image 1 of 1
    • Remove the two screws and washers from the underside of the right side panel.
    Ask FixBot
  10. Newport e500 Power Supply Disassembly: step 10, image 1 of 1
    • Remove the right side panel. Retain hardware for re-assembly.
    Ask FixBot
  11. Newport e500 Power Supply Disassembly, Newport e500 Flow Sensor Cover Disassembly: step 11, image 1 of 1
    • Remove the three screws and washers that secure the flow sensor cover to the pneumatic box assembly. Retain the hardware for re-assembly.
    Ask FixBot
  12. Newport e500 Power Supply Disassembly: step 12, image 1 of 1
    • Remove the flow sensor cover.
    Ask FixBot
  13. Newport e500 Power Supply Disassembly, Newport e500 Pneumatic Box Disassembly: step 13, image 1 of 1
    • Remove the two screws and washers (back corners), one screw and washer (exhalation module support bracket), and two standoffs and washers (front corners) that secure the pneumatic (upper) box assembly to the electronic box assembly. Lift the Pneumatics Box and carefully tilt to one side.
    Ask FixBot
  14. Newport e500 Power Supply Disassembly: step 14, image 1 of 1
    • Remove cables from connectors J1, J2, J3, J4, J5, and J6 on the main PCB (4 connectors are not shown due to being blocked by the side panel). Note the position of these connectors for re-assembly.
    Ask FixBot
  15. Newport e500 Power Supply Disassembly: step 15, image 1 of 1
    • If not already detached, remove the heater cables from J5 and J6 on the DC-DC power supply PCB.
    Ask FixBot
  16. Newport e500 Power Supply Disassembly, Newport e500 Power Supply Disassembly: step 16, image 1 of 1
    • From the underside of the electronics box assembly, remove the four screws and lock washers that secure the power supply to the box assembly.
    Ask FixBot
  17. Newport e500 Power Supply Disassembly: step 17, image 1 of 1
    • Disconnect cables from connectors J1 and J2 on the power supply.
    Ask FixBot
  18. Newport e500 Power Supply Disassembly: step 18, image 1 of 1
    • Lift the power supply out of the electronics box assembly.
    Ask FixBot
Jared McMullen
473 Reputation
4 Guides authored
Cal Poly, Team S7-G16, Paton Spring 2020 Member of Cal Poly, Team S7-G16, Paton Spring 2020
CPSU-PATON-S20S7G16
3 Members
13 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 26
All Time: 333
