Newport e500 Pneumatic Panel Disassembly
View statistics:
Past 24 Hours:
Past 7 Days:
4
Past 30 Days:
25
All Time:
310
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Medical Equipment Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Introduction
Go to step 1 ↓
This guide will show you how to remove the pneumatic panel for further disassembly and replacement. For some helpful tips, go to page 62 in the user manual.
Tools
    1. Newport e500 Pneumatic Panel Disassembly, Newport e500 Top Cover Disassembly: step 1, image 1 of 1
      • Place device so that the top cover is facing you.
      • Open the top cover.
      Ask FixBot
    2. Newport e500 Pneumatic Panel Disassembly: step 2, image 1 of 1
      • Remove the four hex nuts and lock washers (two at each hinge) that secure the cover to the hinges on the left side of the pneumatic box.
      Ask FixBot
    3. Newport e500 Pneumatic Panel Disassembly: step 3, image 1 of 1
      • Remove the cover and set aside. Retain hardware for re-assembly.
      Ask FixBot
    1. Newport e500 Pneumatic Panel Disassembly, Newport e500 Exhalation Module Disassembly: step 4, image 1 of 1
      • Pull up and remove the flexible rubber exhalation outlet boot (push fit).
      Ask FixBot
    2. Newport e500 Pneumatic Panel Disassembly: step 5, image 1 of 1
      • Disconnect the tubes from both sides of the flow sensor and the two tubes from the exhalation valve.
      Ask FixBot
    3. Newport e500 Pneumatic Panel Disassembly: step 6, image 1 of 1
      • Pull the exhalation module straight up to remove it from the GDU.
      Ask FixBot
    1. Newport e500 Pneumatic Panel Disassembly, Newport e500 Air and Oxygen Flow Sensors Disassembly: step 7, image 1 of 1
      • Remove the 2 screws and washers securing the manifold/mixer assembly
      Ask FixBot
    2. Newport e500 Pneumatic Panel Disassembly: step 8, image 1 of 1
      • Slide the manifold/mixer assembly forward to disengage the flow sensors
      Ask FixBot
    3. Newport e500 Pneumatic Panel Disassembly: step 9, image 1 of 1
      • Gently pull each flow sensor straight out from the servo valve, (the flow sensor push-fits into the servo valve port).
      Ask FixBot
    4. Newport e500 Pneumatic Panel Disassembly: step 10, image 1 of 1
      • Disconnect the flow sensor cable from its 10 pin connector at the underside of the flow sensor PCB and lift out the flow sensor.
      Ask FixBot
    1. Newport e500 Pneumatic Panel Disassembly, Newport e500 Pneumatic Panel Disassembly: step 11, image 1 of 1
      • Remove the screw and washer that secure the exhalation manifold support to the pneumatic panel.
      Ask FixBot
    2. Newport e500 Pneumatic Panel Disassembly: step 12, image 1 of 1
      • Pull up on the exhalation valve guide block to remove it from the pneumatic box.
      Ask FixBot
    3. Newport e500 Pneumatic Panel Disassembly: step 13, image 1 of 1
      • Remove the standoff and five screws and washers that secure the pneumatic panel to the pneumatic box.
      Ask FixBot
    4. Newport e500 Pneumatic Panel Disassembly: step 14, image 1 of 1
      • Lift the pneumatic panel out of the box, and from the underside, detach all tubes and the heater wires that connect to the analog PCB.
      Ask FixBot
Seth Aguilar
360 Reputation
3 Guides authored
Cal Poly, Team S7-G16, Paton Spring 2020 Member of Cal Poly, Team S7-G16, Paton Spring 2020
CPSU-PATON-S20S7G16
3 Members
156 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 25
All Time: 310
