Newport e500 Pneumatic Box Disassembly
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
    1. Newport e500 Pneumatic Box Disassembly, Newport e500 Top Cover Disassembly: step 1, image 1 of 1
      • Place device so that the top cover is facing you.
      • Open the top cover.
      Ask FixBot
    2. Newport e500 Pneumatic Box Disassembly: step 2, image 1 of 1
      • Remove the four hex nuts and lock washers (two at each hinge) that secure the cover to the hinges on the left side of the pneumatic box.
      Ask FixBot
    3. Newport e500 Pneumatic Box Disassembly: step 3, image 1 of 1
      • Remove the cover and set aside. Retain hardware for re-assembly.
      Ask FixBot
    1. Newport e500 Pneumatic Box Disassembly, Newport e500 Left Side Panel Disassembly: step 4, image 1 of 1
      • Carefully place the GDU on its right side with the front of the GDU facing you.
      • Remove the three screws and washers at the top edge of the left side panel.
      Ask FixBot
    2. Newport e500 Pneumatic Box Disassembly: step 5, image 1 of 1
      • Remove the two screws and washers from the underside of the left side panel.
      Ask FixBot
    3. Newport e500 Pneumatic Box Disassembly: step 6, image 1 of 1
      • Remove the left side panel. Retain hardware for re-assembly.
      Ask FixBot
    1. Newport e500 Pneumatic Box Disassembly, Newport e500 Right Side Panel Disassembly: step 7, image 1 of 1
      • Carefully place the GDU on its left side.
      Ask FixBot
    2. Newport e500 Pneumatic Box Disassembly: step 8, image 1 of 1
      • Remove the four screws and washers at the top edge of the right side panel.
      Ask FixBot
    3. Newport e500 Pneumatic Box Disassembly: step 9, image 1 of 1
      • Remove the two screws and washers from the underside of the right side panel.
      Ask FixBot
    4. Newport e500 Pneumatic Box Disassembly: step 10, image 1 of 1
      • Remove the right side panel. Retain hardware for re-assembly.
      Ask FixBot
    1. Newport e500 Pneumatic Box Disassembly, Newport e500 Flow Sensor Cover Disassembly: step 11, image 1 of 1
      • Remove the three screws and washers that secure the flow sensor cover to the pneumatic box assembly. Retain the hardware for re-assembly.
      Ask FixBot
    2. Newport e500 Pneumatic Box Disassembly: step 12, image 1 of 1
      • Remove the flow sensor cover.
      Ask FixBot
    1. Newport e500 Pneumatic Box Disassembly, Newport e500 Exhalation Module Disassembly: step 13, image 1 of 1
      • Pull up and remove the flexible rubber exhalation outlet boot (push fit).
      Ask FixBot
    2. Newport e500 Pneumatic Box Disassembly: step 14, image 1 of 1
      • Disconnect the tubes from both sides of the flow sensor and the two tubes from the exhalation valve.
      Ask FixBot
    3. Newport e500 Pneumatic Box Disassembly: step 15, image 1 of 1
      • Pull the exhalation module straight up to remove it from the GDU.
      Ask FixBot
    1. Newport e500 Pneumatic Box Disassembly, Newport e500 Pneumatic Box Disassembly: step 16, image 1 of 1
      • Remove the two screws and washers (back corners), one screw and washer (exhalation module support bracket), and two standoffs and washers (front corners) that secure the pneumatic (upper) box assembly to the electronic box assembly. Lift the Pneumatics Box and carefully tilt to one side.
      Ask FixBot
    2. Newport e500 Pneumatic Box Disassembly: step 17, image 1 of 1
      • Remove cables from connectors J1, J2, J3, J4, J5, and J6 on the main PCB (4 connectors are not shown due to being blocked by the side panel). Note the position of these connectors for re-assembly.
      Ask FixBot
    3. Newport e500 Pneumatic Box Disassembly: step 18, image 1 of 1
      • If not already detached, remove the heater cables from J5 and J6 on the DC-DC power supply PCB.
      Ask FixBot
Jared McMullen
473 Reputation
4 Guides authored
Cal Poly, Team S7-G16, Paton Spring 2020 Member of Cal Poly, Team S7-G16, Paton Spring 2020
CPSU-PATON-S20S7G16
3 Members
156 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 35
All Time: 333
