Newport e500 Internal Battery Disassembly
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
27
All Time:
392
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Medical Equipment Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Introduction
Go to step 1 ↓
This guide will cover the removal and replacement of the internal battery situated within the Newport e500. In order to perform this operation, a screwdriver and torque wrench will be required. Make sure the battery terminals do not come into contact with any other metal object when handled. For more information refer to page 68 of the service manual.
Tools
    1. Newport e500 Internal Battery  Disassembly, Newport e500 Top Cover Disassembly: step 1, image 1 of 1
      • Place device so that the top cover is facing you.
      • Open the top cover.
      Ask FixBot
    2. Newport e500 Internal Battery  Disassembly: step 2, image 1 of 1
      • Remove the four hex nuts and lock washers (two at each hinge) that secure the cover to the hinges on the left side of the pneumatic box.
      Ask FixBot
    3. Newport e500 Internal Battery  Disassembly: step 3, image 1 of 1
      • Remove the cover and set aside. Retain hardware for re-assembly.
      Ask FixBot
    1. Newport e500 Internal Battery  Disassembly, Newport e500 Exhalation Module Disassembly: step 4, image 1 of 1
      • Pull up and remove the flexible rubber exhalation outlet boot (push fit).
      Ask FixBot
    2. Newport e500 Internal Battery  Disassembly: step 5, image 1 of 1
      • Disconnect the tubes from both sides of the flow sensor and the two tubes from the exhalation valve.
      Ask FixBot
    3. Newport e500 Internal Battery  Disassembly: step 6, image 1 of 1
      • Pull the exhalation module straight up to remove it from the GDU.
      Ask FixBot
    1. Newport e500 Internal Battery  Disassembly, Newport e500 Internal Battery  Disassembly: step 7, image 1 of 1
      • Remove the two nuts that hold the battery cover to the electronics box assembly and remove the cover.
      Ask FixBot
    2. Newport e500 Internal Battery  Disassembly: step 8, image 1 of 1
      • Disconnect the black and red wires from the battery terminals.
      Ask FixBot
    3. Newport e500 Internal Battery  Disassembly: step 9, image 1 of 1
      • Pull the battery from the electronics box assembly.
      Ask FixBot
Jeremy
589 Reputation
6 Guides authored
Cal Poly, Team S7-G16, Paton Spring 2020 Member of Cal Poly, Team S7-G16, Paton Spring 2020
CPSU-PATON-S20S7G16
3 Members
156 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 392
