Up to 20% off select tools
Newport e500 Exhalation Module Disassembly
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
22
All Time:
415
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Introduction
Go to step 1 ↓
If you need to access important parts associated with the Newort e500, removal of the exhalation module is an integral step. This step serves as a common pre-requisite to completing other guides. Make sure you are careful with the outlet boot as it is fragile. For more information refer to page 42 of the service manual.
    1. Newport e500 Exhalation Module Disassembly, Newport e500 Exhalation Module Disassembly: step 1, image 1 of 1
      • Pull up and remove the flexible rubber exhalation outlet boot (push fit).
      Ask FixBot
    2. Newport e500 Exhalation Module Disassembly: step 2, image 1 of 1
      • Disconnect the tubes from both sides of the flow sensor and the two tubes from the exhalation valve.
      Ask FixBot
    3. Newport e500 Exhalation Module Disassembly: step 3, image 1 of 1
      • Pull the exhalation module straight up to remove it from the GDU.
      Ask FixBot
Author
with
Jared McMullen
473 Reputation
4 Guides authored
Cal Poly, Team S7-G16, Paton Spring 2020 Member of Cal Poly, Team S7-G16, Paton Spring 2020
CPSU-PATON-S20S7G16
3 Members
156 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 22
All Time: 415
