Up to 20% off select tools
Newport e360 Exhalation Flow Sensor Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
15
Past 30 Days:
44
All Time:
1,075
Comments: 2
2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Replacing the Exhalation Flow Sensor should be relatively quick and easy. There are no tools needed in this replacement. Make sure to give yourself time to thoroughly read through the instructions.
For more information on replacing the exhalation flow sensor, please refer to page 4-2 in the service manual.
    1. Newport e360 Exhalation Flow Sensor Replacement, Exhalation Flow Sensor: step 1, image 1 of 1
      • Turn off ventilator before starting this repair.
      • Shut off or disconnect the air and oxygen gas supplies before starting this repair.
      Ask FixBot
    2. Newport e360 Exhalation Flow Sensor Replacement: step 2, image 1 of 1
      • To avoid damaging equipment, always use standard electrostatic discharge (ESD) precautions
      • Put on an ESD wrist strap or ESD gloves
      Ask FixBot
    3. Newport e360 Exhalation Flow Sensor Replacement: step 3, image 1 of 1
      • Open the Front Panel Door on the lower left front of the ventilator to expose Exhalation Valve EXH2105A and Flow Sensor FLS2101P.
      Ask FixBot
    4. Newport e360 Exhalation Flow Sensor Replacement: step 4, image 1 of 1
      • Remove the Exhalation Valve EXH2105A by releasing the retaining latch.
      Ask FixBot
    5. Newport e360 Exhalation Flow Sensor Replacement: step 5, image 1 of 1
      • Disconnect the Flow Sensor Cable CBL2123P from the plastic body of the Flow Sensor FLS2101P by pulling cable straight up. Do not twist.
      Ask FixBot
    6. Newport e360 Exhalation Flow Sensor Replacement: step 6, image 1 of 1
      • With a twisting motion, pull the plastic Flow Sensor FLS2101P away from the outlet of the Exhalation Valve EXH2105A.
      Ask FixBot
3 other people completed this guide.
Author
with
Lauren Ochoa
192 Reputation
1 Guide authored
Cal Poly, Team S7-G21, Paton Spring 2020 Member of Cal Poly, Team S7-G21, Paton Spring 2020
CPSU-PATON-S20S7G21
3 Members
36 Guides authored
2 Guide Comments
I need this Exhalation Valve EXH2105A part, does anyone have a replacement?
Remigio Rodriguez - Reply Share
I need this
Cable NEWPORT GR-CBL2123P Flow Meter Parts P/N GR-CBL2123P
Please confirmwd to edisonmanullang@gmail.com
Thanks
Edison Simanullang - Reply Share
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 44
All Time: 1,075
