New Nintendo 3DS Cover Plate Replacement
    1. New Nintendo 3DS Cover Plate Replacement, Placing the system on a flat table.: step 1, image 1 of 1
      • Ensure your device is powered off before proceeding. Failure to do so may result in electrical shock or damage to the device.
      • Place the system on a flat stable surface.
      • The Cover Plates will ONLY work with the New Nintendo 3DS. They are not compatible with New Nintendo 3DS XL or any other Nintendo system.
      Ask FixBot
    2. New Nintendo 3DS Cover Plate Replacement, Unscrewing the back cover plate.: step 2, image 1 of 1
      • Use a size #0 phillips-head screwdriver to loosen the screws from the back cover plate. The screws are attached to the cover, so they will not come out completely.
      Ask FixBot
    3. New Nintendo 3DS Cover Plate Replacement, Prying up the back cover plate.: step 3, image 1 of 1
      • Use the nub on the end of the stylus , a fingernail or a plastic opening tool to gently pry on the small slots on each side near the L and R buttons. Once the cover plate begins to separate from the system, gently remove it.
      Ask FixBot
    4. New Nintendo 3DS Cover Plate Replacement, Prying the front cover plate.: step 4, image 1 of 1
      • Use the nub on the end of the stylus , a fingernail, or a plastic opening tool to gently pry on the small slots on each side near the L and R buttons. Once the cover plate begins to separate from the system, gently remove it.
      Ask FixBot
    5. New Nintendo 3DS Cover Plate Replacement, Attaching the front cover plate.: step 5, image 1 of 1
      • Attach the new front cover plate.
      Ask FixBot
    6. New Nintendo 3DS Cover Plate Replacement, Attaching the back cover plate.: step 6, image 1 of 1
      • Attach the new back cover plate and tighten the two #0 phillips-head screws.
      Ask FixBot
You have changed the cover plates on your New Nintendo 3DS system.
5 other people completed this guide.
ethan2226
185 Reputation
1 Guide authored
1 Guide Comment
Hey, this isn't really related but are those custom plates or decals? If so please enlighten me on where to find them. They look really good and I can't find any like this. Thanks in advance!
bobcantfixit - Reply Share
Past 24 Hours: 13
Past 7 Days: 62
Past 30 Days: 274
All Time: 15,427
