New Nintendo 2DS XL Circle Pad Replacement
    1. New Nintendo 2DS XL Circle Pad Replacement, Prepare for disassembly: step 1, image 1 of 1
      • Before you begin, power off the console and remove:
      • The stylus
      • Any game cartridge
      • The microSD card
      Ask FixBot
    2. New Nintendo 2DS XL Circle Pad Replacement, Remove the back cover screws: step 2, image 1 of 1
      • Use a tri‑point Y00 screwdriver to remove the four 6 mm‑long screws located at the four corners of the bottom panel.
      Ask FixBot
    3. New Nintendo 2DS XL Circle Pad Replacement, Release the back cover clips: step 3, image 1 of 2 New Nintendo 2DS XL Circle Pad Replacement, Release the back cover clips: step 3, image 2 of 2
      • Use a spudger to gently pry around the two short edges and front edge (with the stylus cut‑out) to release the clips securing the back cover.
      • Swing the back cover open from its front edge to release the clips along the hinge edge. Don't remove it fully—three cables are connecting it to the motherboard (two on each side and one in the rear).
      Ask FixBot
    4. New Nintendo 2DS XL Circle Pad Replacement, Disconnect the back cover: step 4, image 1 of 3 New Nintendo 2DS XL Circle Pad Replacement, Disconnect the back cover: step 4, image 2 of 3 New Nintendo 2DS XL Circle Pad Replacement, Disconnect the back cover: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
      • Fold the back cover over the hinge edge, keeping the cable connected. Don't strain the cable.
      Ask FixBot
    5. New Nintendo 2DS XL Circle Pad Replacement, Battery Removal: step 5, image 1 of 2 New Nintendo 2DS XL Circle Pad Replacement, Battery Removal: step 5, image 2 of 2
      • The battery is lightly adhered to its enclosure.
      • Use the flat end of a spudger to gently pry the battery out of its plastic enclosure.
      Ask FixBot
    1. New Nintendo 2DS XL Circle Pad Replacement, Disconnect the cameras: step 6, image 1 of 3 New Nintendo 2DS XL Circle Pad Replacement, Disconnect the cameras: step 6, image 2 of 3 New Nintendo 2DS XL Circle Pad Replacement, Disconnect the cameras: step 6, image 3 of 3
      • Flip the back cover over so it's resting on the motherboard. Reposition the back cover if needed to reveal the camera cable connector on the motherboard.
      • Use a spudger to pry up the hinged locking flap on the camera cable ZIF connector.
      • Use tweezers or your fingers to gently pull the cable out of its socket.
      Ask FixBot
    2. New Nintendo 2DS XL Circle Pad Replacement, Circle Pad: step 7, image 1 of 2 New Nintendo 2DS XL Circle Pad Replacement, Circle Pad: step 7, image 2 of 2
      • Use a Phillips screwdriver to remove the two 7.5 mm‑long screws securing the circle pad.
      • Lift the circle pad module off its face plate and flip it over to access its cable connector on the motherboard.
      • A black plastic disc sits between the circle pad module and the circle pad stick. During reassembly, stand the unit on end and hang the plastic disc on the circle pad module. Then, hold the stick from the front and press them back together.
      Ask FixBot
    3. New Nintendo 2DS XL Circle Pad Replacement: step 8, image 1 of 3 New Nintendo 2DS XL Circle Pad Replacement: step 8, image 2 of 3 New Nintendo 2DS XL Circle Pad Replacement: step 8, image 3 of 3
      • Use a spudger to flip up the hinged locking flap on the circle pad cable ZIF connector.
      • Pick up the circle pad module and pull its cable straight out of its connector to remove it.
      Ask FixBot
6 other people completed this guide.
Tim Newman
2,075 Reputation
4 Guides authored
Cal Poly, Team S18-G6, Forte Fall 2017 Member of Cal Poly, Team S18-G6, Forte Fall 2017
CPSU-FORTE-F17S18G6
5 Members
48 Guides authored
6 Guide Comments
I can’t seem to find a New 2ds XL circle pad replacement online, does anyone know if a regular 2ds circle pad works? (Or perhaps a 3ds one?)
Dvdcd - Reply Share
Future Myself, the 3ds circle pad kinda works. The major change here is the screw holes, they were moved in on the 2ds xl, so if you do some sanding and finagling it will work, but it’s not elegant at all.
Dvdcd - Reply Share
Excellent guide, although I believe the 2ds XL requires a Y00 and not a Y0
Gabrielle Watson - Reply Share
Can confirm the other comment, the outside screws are Y00.
If you're not confident removing the top ribbon you can just flip over the back carefully and change the circle pad that way.
You also don't have to remove the battery if it's too hard to remove, my one was stuck down like crazy so I just left it and everything is fine.
I just used a generic 2DS/3DS XL replacement circle pad and it works fine.
Daan - Reply Share
Does anyone know why removing the battery is necessary? Seems unrelated to the circlepad replacement.
Blank - Reply Share
Past 24 Hours: 18
Past 7 Days: 92
Past 30 Days: 549
All Time: 24,814
