New Nintendo 2DS XL Charging Port Replacement
    1. New Nintendo 2DS XL Charging Port Replacement, Prepare for disassembly: step 1, image 1 of 1
      • Before you begin, power off the console and remove:
      • The stylus
      • Any game cartridge
      • The microSD card
      Ask FixBot
    2. New Nintendo 2DS XL Charging Port Replacement, Remove the back cover screws: step 2, image 1 of 1
      • Use a tri‑point Y00 screwdriver to remove the four 6 mm‑long screws located at the four corners of the bottom panel.
      Ask FixBot
    3. New Nintendo 2DS XL Charging Port Replacement, Release the back cover clips: step 3, image 1 of 2 New Nintendo 2DS XL Charging Port Replacement, Release the back cover clips: step 3, image 2 of 2
      • Use a spudger to gently pry around the two short edges and front edge (with the stylus cut‑out) to release the clips securing the back cover.
      • Swing the back cover open from its front edge to release the clips along the hinge edge. Don't remove it fully—three cables are connecting it to the motherboard (two on each side and one in the rear).
      Ask FixBot
    4. New Nintendo 2DS XL Charging Port Replacement, Disconnect the back cover: step 4, image 1 of 3 New Nintendo 2DS XL Charging Port Replacement, Disconnect the back cover: step 4, image 2 of 3 New Nintendo 2DS XL Charging Port Replacement, Disconnect the back cover: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
      • Fold the back cover over the hinge edge, keeping the cable connected. Don't strain the cable.
      Ask FixBot
    5. New Nintendo 2DS XL Charging Port Replacement, Battery Removal: step 5, image 1 of 2 New Nintendo 2DS XL Charging Port Replacement, Battery Removal: step 5, image 2 of 2
      • The battery is lightly adhered to its enclosure.
      • Use the flat end of a spudger to gently pry the battery out of its plastic enclosure.
      Ask FixBot
    1. New Nintendo 2DS XL Charging Port Replacement, Motherboard: step 6, image 1 of 2 New Nintendo 2DS XL Charging Port Replacement, Motherboard: step 6, image 2 of 2
      Buy
      • There are 8 ribbon cables that need to be removed as shown in the picture.
      • 2 of connectors (in green) are friction fit, unlike the rest of the connectors. Remove the cable by pulling it out gently flat in the arrow direction. Do not attempt to open or unlatch these connectors in any way. Doing so will break them.
      • For the remaining 6 (in red), use a pair of tweezers to flip the latches up and pull the ribbon cable out.
      • Note that the second picture shows a broken ribbon connector next to the joystick ribbon connector (to the right of the red arrow). Do not attempt to unlatch this connector as shown in the picture!
      Ask FixBot
    2. New Nintendo 2DS XL Charging Port Replacement: step 7, image 1 of 2 New Nintendo 2DS XL Charging Port Replacement: step 7, image 2 of 2
      • Unplug the following wires from the motherboard using a pair of tweezers.
      Ask FixBot
    3. New Nintendo 2DS XL Charging Port Replacement: step 8, image 1 of 2 New Nintendo 2DS XL Charging Port Replacement: step 8, image 2 of 2
      • Remove the seven 4.4 mm screws using a J00 (or iFixit's Phillips #00) screwdriver bit.
      • Remove the motherboard from the device.
      Ask FixBot
    1. New Nintendo 2DS XL Charging Port Replacement, Charging Port: step 9, image 1 of 1
      • Remove the motherboard and locate the charging port. Flip the the motherboard over.
      Ask FixBot
    2. New Nintendo 2DS XL Charging Port Replacement: step 10, image 1 of 2 New Nintendo 2DS XL Charging Port Replacement: step 10, image 2 of 2
      Ask FixBot
Abolee Diwate
159 Reputation
1 Guide authored
IUPUI, Team S1-G4, Harley Fall 2019 Member of IUPUI, Team S1-G4, Harley Fall 2019
IUPUI-HARLEY-F19S1G4
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 54
Past 30 Days: 253
All Time: 11,717
