New Nintendo 2DS XL Battery Replacement
    1. New Nintendo 2DS XL Battery Replacement, Prepare for disassembly: step 1, image 1 of 1
      • Before you begin, power off the console and remove:
      • The stylus
      • Any game cartridge
      • The microSD card
      Ask FixBot
    2. New Nintendo 2DS XL Battery Replacement, Remove the back cover screws: step 2, image 1 of 1
      • Use a tri‑point Y00 screwdriver to remove the four 6 mm‑long screws located at the four corners of the bottom panel.
      Ask FixBot
    3. New Nintendo 2DS XL Battery Replacement, Release the back cover clips: step 3, image 1 of 2 New Nintendo 2DS XL Battery Replacement, Release the back cover clips: step 3, image 2 of 2
      • Use a spudger to gently pry around the two short edges and front edge (with the stylus cut‑out) to release the clips securing the back cover.
      • Swing the back cover open from its front edge to release the clips along the hinge edge. Don't remove it fully—three cables are connecting it to the motherboard (two on each side and one in the rear).
      Ask FixBot
    4. New Nintendo 2DS XL Battery Replacement, Disconnect the back cover: step 4, image 1 of 3 New Nintendo 2DS XL Battery Replacement, Disconnect the back cover: step 4, image 2 of 3 New Nintendo 2DS XL Battery Replacement, Disconnect the back cover: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
      • Fold the back cover over the hinge edge, keeping the cable connected. Don't strain the cable.
      Ask FixBot
    5. New Nintendo 2DS XL Battery Replacement, Battery Removal: step 5, image 1 of 2 New Nintendo 2DS XL Battery Replacement, Battery Removal: step 5, image 2 of 2
      • The battery is lightly adhered to its enclosure.
      • Use the flat end of a spudger to gently pry the battery out of its plastic enclosure.
      Ask FixBot
50 other people completed this guide.
Tim Newman
2,075 Reputation
4 Guides authored
Cal Poly, Team S18-G6, Forte Fall 2017 Member of Cal Poly, Team S18-G6, Forte Fall 2017
CPSU-FORTE-F17S18G6
5 Members
48 Guides authored
16 Guide Comments
Does the 2ds xl have the same as the new 3ds xl
Royce davenport - Reply Share
no. the 2ds shares the same battery type as the Nintendo DS and the Nintendo switch pro controller.
Jason - Reply Share
@avegaming Nintendo 3DS*, not DS
Jpeg - Reply Share
CTR-003 Battery
stephen cheshire - Reply Share
Do I need to put a sticky pad on the new battery?
bryan sepulveda - Reply Share
Past 24 Hours: 52
Past 7 Days: 391
Past 30 Days: 1,927
All Time: 123,117
