NeuTab N7 Pro Speaker Replacement
    1. NeuTab N7 Pro Speaker Replacement, Speaker: step 1, image 1 of 1
      • Power off your device before beginning disassembly.
      • Insert plastic opening tool and pry back case away from the device, slowly moving the plastic opening tool along the device.
      Ask FixBot
    2. NeuTab N7 Pro Speaker Replacement: step 2, image 1 of 2 NeuTab N7 Pro Speaker Replacement: step 2, image 2 of 2
      • The speaker is attached to the back cover of the device.
      • Hold positive and negative wires as close as possible to the speaker. Use small plastic spudger and fingers to simultaneously lift speaker from cover.
      Ask FixBot
    3. NeuTab N7 Pro Speaker Replacement: step 3, image 1 of 3 NeuTab N7 Pro Speaker Replacement: step 3, image 2 of 3 NeuTab N7 Pro Speaker Replacement: step 3, image 3 of 3
      • Use a soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
      • For a complete guide on how to solder, click here.
      • Be sure not to touch both the positive and negative terminal at the same time.
      Ask FixBot
Travis McLean
322 Reputation
2 Guides authored
USF Tampa, Team 7-1, Cheng Spring 2016 Member of USF Tampa, Team 7-1, Cheng Spring 2016
USFT-CHENG-S16S7G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 33
All Time: 552
