NeuTab N7 Pro Motherboard Replacement
    1. NeuTab N7 Pro Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Power off you device before beginning disassembly.
      • Insert plastic opening tool and pry back case away from the device, slowly moving the plastic opening tool along the device.
      Ask FixBot
    2. NeuTab N7 Pro Motherboard Replacement: step 2, image 1 of 3 NeuTab N7 Pro Motherboard Replacement: step 2, image 2 of 3 NeuTab N7 Pro Motherboard Replacement: step 2, image 3 of 3
      • Use a soldering gun to separate all soldered wires from the motherboard.
      • For a complete guide on how to solder, click here.
      Ask FixBot
    3. NeuTab N7 Pro Motherboard Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Use a spudger to carefully release the tabs on the three ZIF connectors securing the ribbon cables to the motherboard.
      • Carefully pull the ribbons out with tweezers.
      Ask FixBot
    4. NeuTab N7 Pro Motherboard Replacement: step 4, image 1 of 3 NeuTab N7 Pro Motherboard Replacement: step 4, image 2 of 3 NeuTab N7 Pro Motherboard Replacement: step 4, image 3 of 3
      • Use Phillips #J0 Screwdriver to remove three 1mm screws from the motherboard
      Ask FixBot
Travis McLean
322 Reputation
2 Guides authored
USF Tampa, Team 7-1, Cheng Spring 2016 Member of USF Tampa, Team 7-1, Cheng Spring 2016
USFT-CHENG-S16S7G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 40
All Time: 957
