Up to 20% off select tools
NeuTab N7 Pro Battery Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
95
All Time:
2,639
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the battery.
    1. NeuTab N7 Pro Battery Replacement, Battery: step 1, image 1 of 1
      • Power off your device before beginning disassembly.
      • Insert plastic opening tool and pry back case away from the device, slowly moving the plastic opening tool along the device.
      Ask FixBot
    2. NeuTab N7 Pro Battery Replacement: step 2, image 1 of 1
      • Follow the red and black wires from the battery to where they are soldered to the motherboard.
      • Warning: Use caution when handling a soldering iron to avoid injury or damage.
      • Use a soldering iron to separate the positive and negative wires from the motherboard.
      • For a complete guide on how to solder, click here.
      Ask FixBot
    3. NeuTab N7 Pro Battery Replacement: step 3, image 1 of 2 NeuTab N7 Pro Battery Replacement: step 3, image 2 of 2
      • Insert plastic spudger under the battery and slide back and forth, separating the battery from the case.
      Ask FixBot
3 other people completed this guide.
Author
with
Eric Fiske
430 Reputation
2 Guides authored
USF Tampa, Team 7-1, Cheng Spring 2016 Member of USF Tampa, Team 7-1, Cheng Spring 2016
USFT-CHENG-S16S7G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 95
All Time: 2,639
