NeuTab Air7 Motherboard Replacement
    1. NeuTab Air7 Motherboard Replacement, Back Cover: step 1, image 1 of 3 NeuTab Air7 Motherboard Replacement, Back Cover: step 1, image 2 of 3 NeuTab Air7 Motherboard Replacement, Back Cover: step 1, image 3 of 3
      • Ensure your device is powered off before you begin.
      • Use the opening tool to gently pry the back cover off of the tablet, running it along the perimeter of the device.
      Ask FixBot
    1. NeuTab Air7 Motherboard Replacement, Motherboard: step 2, image 1 of 2 NeuTab Air7 Motherboard Replacement, Motherboard: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Remove any adhesive tape attached to the motherboard.
      • Detach the connecting ribbons on the motherboard using tweezers or your fingers.
      Ask FixBot
    2. NeuTab Air7 Motherboard Replacement: step 3, image 1 of 2 NeuTab Air7 Motherboard Replacement: step 3, image 2 of 2
      • The following instructions require soldering, which can risk burn injuries as well as component damage to those novice in the skill. Tread with caution.
      • For a guide on how to solder, click here.
      • De-solder all wires connected to the motherboard to sever the connections.
      Ask FixBot
    3. NeuTab Air7 Motherboard Replacement: step 4, image 1 of 3 NeuTab Air7 Motherboard Replacement: step 4, image 2 of 3 NeuTab Air7 Motherboard Replacement: step 4, image 3 of 3
      • Use a Phillips #00 screwdriver to remove all three 0.8 screws holding the motherboard in place.
      • Remove the motherboard.
      Ask FixBot
Jason Soares
532 Reputation
5 Guides authored
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023 Member of UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 346
