Up to 20% off select tools
NeuTab Air7 Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
59
All Time:
629
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Difficult
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
The battery of the NeuTab Air7 is a vital component that stores all of the electrical power within the device. Without it, your tablet would be unable to function, which is why handling of this component requires a delicate hand. Follow this guide to ensure successful replacement.
    1. NeuTab Air7 Battery Replacement, Back Cover: step 1, image 1 of 3 NeuTab Air7 Battery Replacement, Back Cover: step 1, image 2 of 3 NeuTab Air7 Battery Replacement, Back Cover: step 1, image 3 of 3
      • Ensure your device is powered off before you begin.
      • Use the opening tool to gently pry the back cover off of the tablet, running it along the perimeter of the device.
      Ask FixBot
    1. NeuTab Air7 Battery Replacement, Battery: step 2, image 1 of 2 NeuTab Air7 Battery Replacement, Battery: step 2, image 2 of 2
      • The following instructions require soldering, which can risk burn injuries as well as component damage for those novice in the skill. Tread with caution.
      • For a guide on how to solder, click here.
      • Remove any adhesive tape that is holding the wires protruding from the battery down.
      • De-solder the red and black wire ends that connect the battery to the motherboard.
      Ask FixBot
    2. NeuTab Air7 Battery Replacement: step 3, image 1 of 2 NeuTab Air7 Battery Replacement: step 3, image 2 of 2
      • Using metal tools can cause damage to the battery and potentially create a fire hazard. ESD safe tools are recommended for this operation.
      • Wedge a plastic or nylon spudger underneath the battery, moving it back and forth to separate it from the device.
      • Remove the battery.
      Ask FixBot
Author
with
Jason Soares
532 Reputation
5 Guides authored
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023 Member of UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 59
All Time: 629
