Up to 20% off select tools
Network Card
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
56
All Time:
563
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 35 minutes
Difficulty: Easy
Community-Contributed Guide
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Network Card
Tools
    1. Network Card, Bottom Cover: step 1, image 1 of 1
      • Use a Philips J1 driver to remove eight screws securing the bottom case.
      • Remove all of the 8 screws and the bottom panel should pop off.
      Ask FixBot
    2. Network Card: step 2, image 1 of 1
      • After that you are in and now can change most of the components, which we also have tutorials for.
      Ask FixBot
    1. Network Card, Network Card: step 3, image 1 of 1
      • Remove the screw with a Philips J1 driver.
      • Try to remove the cables by hand or if you really can't, then use a spudger to carefully pry them up.
      • After removing the screw and the cables, you can safely remove the network card.
      Ask FixBot
    2. Network Card: step 4, image 1 of 1
      • If you need to change the Wireless card and nothing else then now is the time to do so.
      • After the previous step, you are good to go.
      Ask FixBot
Author
with
Regome
866 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 56
All Time: 563
