Netgear WGR614v9 Motherboard Replacement
    1. Netgear WGR614v9 Motherboard Replacement, Lower Case: step 1, image 1 of 1
      • Rotate the device so that the bottom is facing up.
      Ask FixBot
    2. Netgear WGR614v9 Motherboard Replacement: step 2, image 1 of 2 Netgear WGR614v9 Motherboard Replacement: step 2, image 2 of 2
      • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
      • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
      Ask FixBot
    3. Netgear WGR614v9 Motherboard Replacement: step 3, image 1 of 2 Netgear WGR614v9 Motherboard Replacement: step 3, image 2 of 2
      • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
      Ask FixBot
    4. Netgear WGR614v9 Motherboard Replacement: step 4, image 1 of 1
      • Lift the bottom casing straight up from the router.
      Ask FixBot
    1. Netgear WGR614v9 Motherboard Replacement, Motherboard: step 5, image 1 of 1
      • Remove the clear plastic casing by lifting it straight up from the router.
      Ask FixBot
    2. Netgear WGR614v9 Motherboard Replacement: step 6, image 1 of 2 Netgear WGR614v9 Motherboard Replacement: step 6, image 2 of 2
      • Separate the motherboard from the top shell by lifting it straight up from the router.
      Ask FixBot
Ryan Murphy
488 Reputation
4 Guides authored
Cal Poly, Team 21-24, Maness Fall 2011 Member of Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 2,670
