Netgear WGR614v9 Capacitor Replacement
    1. Netgear WGR614v9 Capacitor Replacement, Lower Case: step 1, image 1 of 1
      • Rotate the device so that the bottom is facing up.
      Ask FixBot
    2. Netgear WGR614v9 Capacitor Replacement: step 2, image 1 of 2 Netgear WGR614v9 Capacitor Replacement: step 2, image 2 of 2
      • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
      • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
      Ask FixBot
    3. Netgear WGR614v9 Capacitor Replacement: step 3, image 1 of 2 Netgear WGR614v9 Capacitor Replacement: step 3, image 2 of 2
      • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
      Ask FixBot
    4. Netgear WGR614v9 Capacitor Replacement: step 4, image 1 of 1
      • Lift the bottom casing straight up from the router.
      Ask FixBot
    1. Netgear WGR614v9 Capacitor Replacement, Motherboard: step 5, image 1 of 1
      • Remove the clear plastic casing by lifting it straight up from the router.
      Ask FixBot
    2. Netgear WGR614v9 Capacitor Replacement: step 6, image 1 of 2 Netgear WGR614v9 Capacitor Replacement: step 6, image 2 of 2
      • Separate the motherboard from the top shell by lifting it straight up from the router.
      Ask FixBot
    1. Netgear WGR614v9 Capacitor Replacement, Capacitor: step 7, image 1 of 2 Netgear WGR614v9 Capacitor Replacement, Capacitor: step 7, image 2 of 2
      • Rotate the motherboard so that the top is facing up.
      • Set the motherboard on a flat clean surface.
      Ask FixBot
    2. Netgear WGR614v9 Capacitor Replacement: step 8, image 1 of 2 Netgear WGR614v9 Capacitor Replacement: step 8, image 2 of 2
      • The capacitor can be found at the location shown.
      Ask FixBot
    3. Netgear WGR614v9 Capacitor Replacement: step 9, image 1 of 2 Netgear WGR614v9 Capacitor Replacement: step 9, image 2 of 2
      • Rotate the motherboard so that the bottom is facing up.
      • Locate the two soldered contacts of the capacitor.
      Ask FixBot
    4. Netgear WGR614v9 Capacitor Replacement: step 10, image 1 of 3 Netgear WGR614v9 Capacitor Replacement: step 10, image 2 of 3 Netgear WGR614v9 Capacitor Replacement: step 10, image 3 of 3
      • Rotate the motherboard 180 degrees.
      • Do not refer to the pictures in this step for proper de-soldering and soldering techniques. They are for illustration purposes only.
      • Refer to this link for proper de-soldering and soldering techniques.
      • Pull the capacitor from the other side of the circuit board once the solder is liquified.
      • To replace the capacitor, orient the negative side of the capacitor (indicated by a white stripe and a negative sign) so that it aligns with the shaded white region of the circle indicating the capacitor's position on the motherboard.
      Ask FixBot
Kyle Moore
95 Reputation
1 Guide authored
Cal Poly, Team 21-24, Maness Fall 2011 Member of Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
4 Members
48 Guides authored
1 Guide Comment
looks like that's a 220microF at 25V right ?
probably better to replace it with a similar 220microF, but with higher voltage rating.
email_etran - Reply Share
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 45
All Time: 3,832
