Netgear WGR614v9 Antenna Replacement
    1. Netgear WGR614v9 Antenna Replacement, Lower Case: step 1, image 1 of 1
      • Rotate the device so that the bottom is facing up.
      Ask FixBot
    2. Netgear WGR614v9 Antenna Replacement: step 2, image 1 of 2 Netgear WGR614v9 Antenna Replacement: step 2, image 2 of 2
      • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
      • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
      Ask FixBot
    3. Netgear WGR614v9 Antenna Replacement: step 3, image 1 of 2 Netgear WGR614v9 Antenna Replacement: step 3, image 2 of 2
      • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
      Ask FixBot
    4. Netgear WGR614v9 Antenna Replacement: step 4, image 1 of 1
      • Lift the bottom casing straight up from the router.
      Ask FixBot
    1. Netgear WGR614v9 Antenna Replacement, Motherboard: step 5, image 1 of 1
      • Remove the clear plastic casing by lifting it straight up from the router.
      Ask FixBot
    2. Netgear WGR614v9 Antenna Replacement: step 6, image 1 of 2 Netgear WGR614v9 Antenna Replacement: step 6, image 2 of 2
      • Separate the motherboard from the top shell by lifting it straight up from the router.
      Ask FixBot
    1. Netgear WGR614v9 Antenna Replacement, Antenna: step 7, image 1 of 2 Netgear WGR614v9 Antenna Replacement, Antenna: step 7, image 2 of 2
      • Rotate the motherboard so that the top is facing up.
      • Set the motherboard on a flat clean surface.
      Ask FixBot
    2. Netgear WGR614v9 Antenna Replacement: step 8, image 1 of 2 Netgear WGR614v9 Antenna Replacement: step 8, image 2 of 2
      • Do not refer to the pictures in this step for proper de-soldering and soldering techniques. They are for illustration purposes only.
      • Refer to this link for proper de-soldering and soldering techniques.
      • Be patient. This may take some time depending on the quality of your soldering iron.
      Ask FixBot
    3. Netgear WGR614v9 Antenna Replacement: step 9, image 1 of 1
      • Peel off the yellow tape holding the wires.
      • Set the tape aside on a clean surface so that it can be reused.
      Ask FixBot
    4. Netgear WGR614v9 Antenna Replacement: step 10, image 1 of 2 Netgear WGR614v9 Antenna Replacement: step 10, image 2 of 2
      • Extend the antenna outwards from the device so that it is straight.
      • Locate the clips that hold the antenna onto the router.
      • Push the clips in with one hand and pull the antenna out with your other hand. Slightly twist the antenna until it becomes free from the hole.
      Ask FixBot
    5. Netgear WGR614v9 Antenna Replacement: step 11, image 1 of 1
      • Pull out the antenna as well as the connected wire.
      Ask FixBot
3 other people completed this guide.
Ryan Murphy
488 Reputation
4 Guides authored
Cal Poly, Team 21-24, Maness Fall 2011 Member of Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 42
All Time: 8,298
