Netgear Arlo Charging Port Replacement
    1. Netgear Arlo Charging Port Replacement, Plastic Housing: step 1, image 1 of 1
      • Remove the 2 (3.5mm) housing screws with a J0 screwdriver.
      Ask FixBot
    2. Netgear Arlo Charging Port Replacement: step 2, image 1 of 2 Netgear Arlo Charging Port Replacement: step 2, image 2 of 2
      • Slide the unlocked battery cover forward to remove 2 (3.5mm) screws, that are behind the cover.
      Ask FixBot
    3. Netgear Arlo Charging Port Replacement: step 3, image 1 of 1
      • Open the battery cover and remove the 2 (3.5mm") screws from under the cover.
      Ask FixBot
    4. Netgear Arlo Charging Port Replacement: step 4, image 1 of 3 Netgear Arlo Charging Port Replacement: step 4, image 2 of 3 Netgear Arlo Charging Port Replacement: step 4, image 3 of 3
      • Use a plastic opening tool to start separating the plastic housing from the front side of the battery cover.
      • Next, start separating the plastic cover from the rear of the plastic housing, and work your way down the seam line.
      • Make sure the plastics snaps on the front of the plastic get unhooked from the grey plastic ring around the front of the camera.
      Ask FixBot
    5. Netgear Arlo Charging Port Replacement: step 5, image 1 of 3 Netgear Arlo Charging Port Replacement: step 5, image 2 of 3 Netgear Arlo Charging Port Replacement: step 5, image 3 of 3
      • Remove the screw (3.5mm) near the sync button holding the opposite side of the camera on.
      • Remove the second screw (3.5mm) on the back of the camera to remove the second housing.
      • Once the screws are removed use an opening tool to pry back the second plastic mount.
      Ask FixBot
    1. Netgear Arlo Charging Port Replacement, Lens Assembly: step 6, image 1 of 1
      • Remove 4 (6mm) large screws with a J00 screwdriver.
      • There are 2 on each side. This will allow you to remove the clear housing from the white housing.
      Ask FixBot
    2. Netgear Arlo Charging Port Replacement: step 7, image 1 of 2 Netgear Arlo Charging Port Replacement: step 7, image 2 of 2
      • Once screws are removed, pull apart the clear housing.
      • Remove rod from camera cover.
      Ask FixBot
    3. Netgear Arlo Charging Port Replacement: step 8, image 1 of 3 Netgear Arlo Charging Port Replacement: step 8, image 2 of 3 Netgear Arlo Charging Port Replacement: step 8, image 3 of 3
      • Remove Large ribbon cable first to disconnect front of camera from main body.
      • Remove 4 (3.5mm) small black screws from motherboard of the camera unit.
      • Remove smaller ribbon cable from underneath yellow tape.
      Ask FixBot
    4. Netgear Arlo Charging Port Replacement: step 9, image 1 of 1
      • Once all ribbon cables are removed, remove the motherboard and camera assembly by pulling up on the black camera motherboard.
      Ask FixBot
    1. Netgear Arlo Charging Port Replacement, Charging Port: step 10, image 1 of 1
      • Remove the 2 (.135") housing screws with a JIS00 screwdriver
      Ask FixBot
    2. Netgear Arlo Charging Port Replacement: step 11, image 1 of 1
      • Remove 4 (.135") screws on the inside of the battery compartment using the JIS 00 screwdriver.
      Ask FixBot
    3. Netgear Arlo Charging Port Replacement: step 12, image 1 of 1
      • Slide the two halves apart
      Ask FixBot
    4. Netgear Arlo Charging Port Replacement: step 13, image 1 of 1
      • Remove the 2 (.135") screws holding the charging port on using the JIS 00 screwdriver.
      Ask FixBot
    5. Netgear Arlo Charging Port Replacement: step 14, image 1 of 2 Netgear Arlo Charging Port Replacement: step 14, image 2 of 2
      • Remove the ribbon by prying the black ribbon holder up using the opening tool.
      • Pull the ribbon away from the charging port.
      Ask FixBot
2 other people completed this guide.
Brian Johnson
187 Reputation
1 Guide authored
IUPUI, Team S2-G1, Freund Spring 2018 Member of IUPUI, Team S2-G1, Freund Spring 2018
IUPUI-FREUND-S18S2G1
2 Members
24 Guides authored
4 Guide Comments
Great Job, Thank you!
Bob Olive Sr - Reply Share
Great thanks where did you get the replacement cable please thanks Mike
mikewalters1951 - Reply Share
where did you get the replacement cable please thanks  BOB
robertwatkins61 - Reply Share
Any hints on where the new port came from? I have the baby monitor and the port is cheap rubbish and needs replacing. Thanks
David - Reply Share
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 31
All Time: 6,045
