Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement
  1. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Removal from Wall: step 1, image 1 of 2 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Removal from Wall: step 1, image 2 of 2
    • Grasp the display's metal outer ring with your fingers and pull directly away from the wall.
    Ask FixBot
  2. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Open Display: step 2, image 1 of 1
    • Turn the display over.
    • Remove the four 6 mm screws from the back of the display using a Phillips #0 screwdriver.
    Ask FixBot
  3. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove the back of the display: step 3, image 1 of 2 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove the back of the display: step 3, image 2 of 2
    • Pinch the gray 20-pin connector with your fingers and pull directly away from the display.
    • Do NOT pull too far as there is a ribbon on the back panel connecting the 20-pin connector to the display.
    Ask FixBot
  4. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the base connection ribbon cable.: step 4, image 1 of 3 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the base connection ribbon cable.: step 4, image 2 of 3 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the base connection ribbon cable.: step 4, image 3 of 3
    • Locate the blue pull tab at the end of the ribbon which says, "1. Pull".
    • Grasp the tab with your fingers and pull directly away from the motherboard.
    Ask FixBot
  5. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Lift battery from the base: step 5, image 1 of 2 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Lift battery from the base: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Locate the blue tab which says, "2. Pull".
    • Use tweezers to pull the battery up and away from the display.
    • Do NOT pull too far, as the battery is still connected to the motherboard and must be unplugged.
    Ask FixBot
  6. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the battery from the motherboard: step 6, image 1 of 2 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the battery from the motherboard: step 6, image 2 of 2
    • Locate the blue tab which says "3 unplug".
    • Grasp the battery with your fingers. Pull gently directly away from the display to unplug the battery from the motherboard.
    Ask FixBot
  7. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove battery from the display: step 7, image 1 of 3 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove battery from the display: step 7, image 2 of 3 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove battery from the display: step 7, image 3 of 3
    • Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display.
    Ask FixBot
  8. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Locate auto-away sensor: step 8, image 1 of 1
    • Locate the auto-away sensor.
    Ask FixBot
  9. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove screws: step 9, image 1 of 2 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove screws: step 9, image 2 of 2
    • Remove the four 3mm screws with a #0 Phillips screwdriver.
    • Remove the one 4mm screw located at the edge of the auto-away sensor. Use a #0 Phillips screwdriver.
    Ask FixBot
  10. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove auto-away sensor: step 10, image 1 of 3 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove auto-away sensor: step 10, image 2 of 3 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove auto-away sensor: step 10, image 3 of 3
    Buy
    • Lift the auto-away sensor from motherboard using tweezers.
    • Peel the copper foil gently from the EMI shield.
    Ask FixBot
2 other people completed this guide.
Justin Curry
264 Reputation
2 Guides authored
USF Tampa, Team 11-5, Blackwell Fall 2014 Member of USF Tampa, Team 11-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G5
5 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 36
All Time: 2,571
