Up to 20% off select tools
Nest Hello O-Ring Replacement
Views: 5.6K
View statistics:
Past 24 Hours:
9
Past 7 Days:
34
Past 30 Days:
119
All Time:
5,643
Comments: 21
19 comments on steps, 2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 9 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will help you replace a leaky O-Ring caused by exposure to the elements or damage during disassembly. All you will need to access this are iFixit opening picks. It is recommended that this is replaced anytime the device is opened as it can be pinched or torn during removal of the face plate or device housing.
    1. Nest Hello O-Ring Replacement, Casing and Faceplate: step 1, image 1 of 1
      • Insert the pick between the black faceplate and white casing of the Nest Hello.
      • Pry the faceplate away from the device with the opening pick.
      • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
      • Completely remove the faceplate from the device, do not be afraid to pull hard.
      Ask FixBot
    2. Nest Hello O-Ring Replacement: step 2, image 1 of 2 Nest Hello O-Ring Replacement: step 2, image 2 of 2
      • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
      Ask FixBot
    3. Nest Hello O-Ring Replacement: step 3, image 1 of 3 Nest Hello O-Ring Replacement: step 3, image 2 of 3 Nest Hello O-Ring Replacement: step 3, image 3 of 3
      • Insert opening pick between the white casing and the black internal circuitry and pry it out.
      • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
      Ask FixBot
    1. Nest Hello O-Ring Replacement, O-Ring: step 4, image 1 of 1
      • Remove the O-Ring (colored blue) from the device. It is placed around the edge of the motherboard.
      Ask FixBot
3 other people completed this guide.
Author
with
Jason Valencia
428 Reputation
1 Guide authored
2 Guide Comments
Is there a link available for spare replacement parts? I can’t seem to find anything other than replacement internal batteries . Thanks!
Andres Chavez - Reply Share
Also looking for this replacement part. Googling did not produce results.
KB_KB - Reply Share
Past 24 Hours: 9
Past 7 Days: 34
Past 30 Days: 119
All Time: 5,643
