Nest Hello Casing and Faceplate Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
28
Past 30 Days:
96
All Time:
4,143
Comments: 19
17 comments on steps, 2 guide comments.
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide will show how to remove the faceplate and casing from the Nest Hello.
Tools
    1. Nest Hello Casing and Faceplate Replacement, Casing and Faceplate: step 1, image 1 of 1
      • Insert the pick between the black faceplate and white casing of the Nest Hello.
      • Pry the faceplate away from the device with the opening pick.
      • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
      • Completely remove the faceplate from the device, do not be afraid to pull hard.
      Ask FixBot
    2. Nest Hello Casing and Faceplate Replacement: step 2, image 1 of 2 Nest Hello Casing and Faceplate Replacement: step 2, image 2 of 2
      • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
      Ask FixBot
    3. Nest Hello Casing and Faceplate Replacement: step 3, image 1 of 3 Nest Hello Casing and Faceplate Replacement: step 3, image 2 of 3 Nest Hello Casing and Faceplate Replacement: step 3, image 3 of 3
      • Insert opening pick between the white casing and the black internal circuitry and pry it out.
      • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
      Ask FixBot
2 Guide Comments
Are Replacement parts available anywhere? Can’t seem to find anything… thanks!
Andres Chavez - Reply Share
Aside from fine grit sanding and spray painting or using a silicone cover, has anyone found a creative way to fix the delaminated an existing Gen 1 Google Nest wired / Nest Hello doorbell faceplate (remove the rest of the flaking off laminate)?
RickSoFlo - Reply Share
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 96
All Time: 4,143
