Up to 20% off select tools
Nest Hello Button Replacement
Views: 4.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
28
Past 30 Days:
141
All Time:
4,581
Comments: 21
19 comments on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 30 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
If the doorbell button on your Nest Hello is cracked or leaking, this guide will help you access and replace it. During disassembly, it is easy to damage the waterproofing O-Ring, so plan on replacing that as well. This does involve removing all of the internals from the device using the iFixit opening picks, Phillips #000 screwdriver, and tweezers. Be sure to take your time and keep track of screws and other parts.
    1. Nest Hello Button Replacement, Casing and Faceplate: step 1, image 1 of 1
      • Insert the pick between the black faceplate and white casing of the Nest Hello.
      • Pry the faceplate away from the device with the opening pick.
      • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
      • Completely remove the faceplate from the device, do not be afraid to pull hard.
      Ask FixBot
    2. Nest Hello Button Replacement: step 2, image 1 of 2 Nest Hello Button Replacement: step 2, image 2 of 2
      • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
      Ask FixBot
    3. Nest Hello Button Replacement: step 3, image 1 of 3 Nest Hello Button Replacement: step 3, image 2 of 3 Nest Hello Button Replacement: step 3, image 3 of 3
      • Insert opening pick between the white casing and the black internal circuitry and pry it out.
      • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
      Ask FixBot
    1. Nest Hello Button Replacement, Motherboard: step 4, image 1 of 1
      • Use the Phillips #000 to remove the two screws holding the ribbon cable to the white casing.
      Ask FixBot
    2. Nest Hello Button Replacement: step 5, image 1 of 2 Nest Hello Button Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Grip the connector with the tweezers as shown and pull it away from the casing.
      Ask FixBot
    3. Nest Hello Button Replacement: step 6, image 1 of 1
      • Remove the six smaller screws shown with the Phillips #000 screwdriver.
      • Remove the three larger screws shown with the Phillips #000 screwdriver.
      Ask FixBot
    4. Nest Hello Button Replacement: step 7, image 1 of 2 Nest Hello Button Replacement: step 7, image 2 of 2
      • Holding the device as shown push the circuit board away from you and up to free it from the clips.
      Ask FixBot
    5. Nest Hello Button Replacement: step 8, image 1 of 2 Nest Hello Button Replacement: step 8, image 2 of 2
      • Use the Phillips #000 screwdriver to remove the three screws holding the last circuit board to the black plastic housing.
      Ask FixBot
    6. Nest Hello Button Replacement: step 9, image 1 of 1
      • Insert the pick underneath the black connectors and pry them upward to disconnect them from the circuit board.
      • Work your way around the device, prying the circuit board away from the housing.
      • Make sure to feed the wires when taking off the circuit board.
      Ask FixBot
      • Once the circuitboard is free from the plastic housing, the button can be removed by pushing on it from the front side.
      Ask FixBot
Author
with
Daniel Moore
944 Reputation
6 Guides authored
2 Guide Comments
Where do you get the parts. Google is no help. I’m trying to get the black faceplate from your first step. I can’t find it.
Ryan Gauder - Reply Share
Where do I buy a button?
Joel Lundi - Reply Share
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 141
All Time: 4,581
