Up to 20% off select tools
Nest Hello Battery Replacement
Views: 91K
View statistics:
Past 24 Hours:
86
Past 7 Days:
348
Past 30 Days:
1,246
All Time:
91,414
Comments: 83
35 comments on steps, 48 guide comments.
Go to guide comments
Completed: 38
38 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 25 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
If your Nest Hello is losing charge faster than it used to, or refusing to power-on despite troubleshooting, this guide will help you access a faulty battery. The following steps will require the iFixit opening picks, Phillips #000 screwdriver, and tweezers. While removing the faceplate and casing from the device it is easy to damage the waterproofing O-Ring, so plan on replacing that as well.
    1. Nest Hello Battery Replacement, Casing and Faceplate: step 1, image 1 of 1
      • Insert the pick between the black faceplate and white casing of the Nest Hello.
      • Pry the faceplate away from the device with the opening pick.
      • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
      • Completely remove the faceplate from the device, do not be afraid to pull hard.
      Ask FixBot
    2. Nest Hello Battery Replacement: step 2, image 1 of 2 Nest Hello Battery Replacement: step 2, image 2 of 2
      • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
      Ask FixBot
    3. Nest Hello Battery Replacement: step 3, image 1 of 3 Nest Hello Battery Replacement: step 3, image 2 of 3 Nest Hello Battery Replacement: step 3, image 3 of 3
      • Insert opening pick between the white casing and the black internal circuitry and pry it out.
      • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
      Ask FixBot
    1. Nest Hello Battery Replacement, Battery: step 4, image 1 of 3 Nest Hello Battery Replacement, Battery: step 4, image 2 of 3 Nest Hello Battery Replacement, Battery: step 4, image 3 of 3
      • Once the back casing is removed, disconnect the battery cable and remove the battery from the device.
      Ask FixBot
38 other people completed this guide.
Author
with
Daniel Moore
944 Reputation
6 Guides authored
48 Guide Comments
Any recommendations as to where we can find a replacement battery? Model #, specs?
Patrick Ouellet - Reply Share
Flujoy 280mAh/3.7V Replacement Battery for Nest C1241290 Vido Doorbell Wired NC5100US Hello 1ICP7/17/26
About $16 from Amazon
Joel Lundi - Reply Share
Battery and o-ring part source?
Ryan - Reply Share
What is the replacement battery?
Leon Sparrow - Reply Share
Search Amazon for the following and you should find several choices:
Nest Hello NC5100US C1241290 Video Doorbell Wired
JOHN ZUCKERMAN - Reply Share
Past 24 Hours: 86
Past 7 Days: 348
Past 30 Days: 1,246
All Time: 91,414
