Nest Dropcam Pro Mounting Clips Replacement
    1. Nest Dropcam Pro Mounting Clips Replacement, Outer Case: step 1, image 1 of 1
      • Press in the mounting clips on each side of the case to remove the camera from the mount.
      Ask FixBot
    2. Nest Dropcam Pro Mounting Clips Replacement: step 2, image 1 of 2 Nest Dropcam Pro Mounting Clips Replacement: step 2, image 2 of 2
      • Using a Philips #0 screwdriver, remove the four 3 mm screws.
      Ask FixBot
    3. Nest Dropcam Pro Mounting Clips Replacement: step 3, image 1 of 2 Nest Dropcam Pro Mounting Clips Replacement: step 3, image 2 of 2
      • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
      • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
      Ask FixBot
    1. Nest Dropcam Pro Mounting Clips Replacement, Mounting Clips: step 4, image 1 of 2 Nest Dropcam Pro Mounting Clips Replacement, Mounting Clips: step 4, image 2 of 2
      • Using a Philips #0 screwdriver, remove the four 4 mm screws that are attaching the mounting clips to the case.
      Ask FixBot
    2. Nest Dropcam Pro Mounting Clips Replacement: step 5, image 1 of 1
      • Lift the mounting clips away from the case.
      Ask FixBot
David Foens
914 Reputation
6 Guides authored
USF Tampa, Team 15-4, Blackwell Fall 2015 Member of USF Tampa, Team 15-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 116
All Time: 1,712
