Nest Dropcam Pro Motherboard Replacement
    1. Nest Dropcam Pro Motherboard Replacement, Outer Case: step 1, image 1 of 1
      • Press in the mounting clips on each side of the case to remove the camera from the mount.
      Ask FixBot
    2. Nest Dropcam Pro Motherboard Replacement: step 2, image 1 of 2 Nest Dropcam Pro Motherboard Replacement: step 2, image 2 of 2
      • Using a Philips #0 screwdriver, remove the four 3 mm screws.
      Ask FixBot
    3. Nest Dropcam Pro Motherboard Replacement: step 3, image 1 of 2 Nest Dropcam Pro Motherboard Replacement: step 3, image 2 of 2
      • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
      • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
      Ask FixBot
    1. Nest Dropcam Pro Motherboard Replacement, Motherboard: step 4, image 1 of 2 Nest Dropcam Pro Motherboard Replacement, Motherboard: step 4, image 2 of 2
      • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
      Ask FixBot
    2. Nest Dropcam Pro Motherboard Replacement: step 5, image 1 of 2 Nest Dropcam Pro Motherboard Replacement: step 5, image 2 of 2
      • Pull the motherboard away from the back case.
      • Unplug the red and black cable connecting the motherboard to the back case.
      Ask FixBot
    3. Nest Dropcam Pro Motherboard Replacement: step 6, image 1 of 2 Nest Dropcam Pro Motherboard Replacement: step 6, image 2 of 2
      • Using a Philips #0 screwdriver, remove the four 2 mm screws.
      Ask FixBot
    4. Nest Dropcam Pro Motherboard Replacement: step 7, image 1 of 2 Nest Dropcam Pro Motherboard Replacement: step 7, image 2 of 2
      • Lift the lens and LED assembly away from the motherboard.
      • Unplug the yellow and white cable from the motherboard.
      Ask FixBot
7 other people completed this guide.
David Foens
914 Reputation
6 Guides authored
USF Tampa, Team 15-4, Blackwell Fall 2015 Member of USF Tampa, Team 15-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G4
3 Members
72 Guides authored
7 Guide Comments
where we can get the mother board to replace
fercervantes - Reply Share
I need this too
kundimberi - Reply Share
Where can I get the motherboard
xtogamba - Reply Share
Can't find it either. Silly to write an entire article for credit if parts arent actually available.
Bruce Weissman - Reply Share
searched for the MB online?? Why no mention of where to get it??
anonymous 6761 - Reply Share
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 111
All Time: 9,585
