Up to 20% off select tools
Nest Dropcam Pro Camera Lens Replacement
Views: 4.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
99
All Time:
4,647
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide is used to replace the camera lens of the Nest Dropcam Pro. Make sure the device is unplugged before opening.
    1. Nest Dropcam Pro Camera Lens Replacement, Outer Case: step 1, image 1 of 1
      • Press in the mounting clips on each side of the case to remove the camera from the mount.
      Ask FixBot
    2. Nest Dropcam Pro Camera Lens Replacement: step 2, image 1 of 2 Nest Dropcam Pro Camera Lens Replacement: step 2, image 2 of 2
      • Using a Philips #0 screwdriver, remove the four 3 mm screws.
      Ask FixBot
    3. Nest Dropcam Pro Camera Lens Replacement: step 3, image 1 of 2 Nest Dropcam Pro Camera Lens Replacement: step 3, image 2 of 2
      • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
      • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
      Ask FixBot
    1. Nest Dropcam Pro Camera Lens Replacement, Motherboard: step 4, image 1 of 2 Nest Dropcam Pro Camera Lens Replacement, Motherboard: step 4, image 2 of 2
      • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
      Ask FixBot
    2. Nest Dropcam Pro Camera Lens Replacement: step 5, image 1 of 2 Nest Dropcam Pro Camera Lens Replacement: step 5, image 2 of 2
      • Pull the motherboard away from the back case.
      • Unplug the red and black cable connecting the motherboard to the back case.
      Ask FixBot
    3. Nest Dropcam Pro Camera Lens Replacement: step 6, image 1 of 2 Nest Dropcam Pro Camera Lens Replacement: step 6, image 2 of 2
      • Using a Philips #0 screwdriver, remove the four 2 mm screws.
      Ask FixBot
    4. Nest Dropcam Pro Camera Lens Replacement: step 7, image 1 of 2 Nest Dropcam Pro Camera Lens Replacement: step 7, image 2 of 2
      • Lift the lens and LED assembly away from the motherboard.
      • Unplug the yellow and white cable from the motherboard.
      Ask FixBot
    1. Nest Dropcam Pro Camera Lens Replacement, Camera Lens: step 8, image 1 of 2 Nest Dropcam Pro Camera Lens Replacement, Camera Lens: step 8, image 2 of 2
      Ask FixBot
    2. Nest Dropcam Pro Camera Lens Replacement: step 9, image 1 of 3 Nest Dropcam Pro Camera Lens Replacement: step 9, image 2 of 3 Nest Dropcam Pro Camera Lens Replacement: step 9, image 3 of 3
      • Peel off the paper seal holding the Lens and LEDs together.
      • Disconnect the red and white wire from the bottom board.
      Ask FixBot
    3. Nest Dropcam Pro Camera Lens Replacement: step 10, image 1 of 2 Nest Dropcam Pro Camera Lens Replacement: step 10, image 2 of 2
      • Lift up the foam cover to reveal a second screw underneath.
      • Using a Philips #0 screwdriver, remove the two 3 mm screws.
      Ask FixBot
    4. Nest Dropcam Pro Camera Lens Replacement: step 11, image 1 of 1
      • With the screws gone, lift the camera lens away from the remaining components.
      Ask FixBot
2 other people completed this guide.
Author
with
David Foens
914 Reputation
6 Guides authored
USF Tampa, Team 15-4, Blackwell Fall 2015 Member of USF Tampa, Team 15-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G4
3 Members
72 Guides authored
2 Guide Comments
Where do you get replacement lens?
Jim Fischer - Reply Share
good morning , is there any store on the USA where i can send my drop camera ti get fix? it fell and doesn't want to broadcast any image.
andres - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 99
All Time: 4,647
