Nest Cam Motherboard Replacement
  1. Nest Cam Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Remove the four 6 mm screws from the back panel with the JIS 000 screwdriver.
    • We suggest designated areas to keep track of all screws.
    Ask FixBot
  2. Nest Cam Motherboard Replacement: step 2, image 1 of 3 Nest Cam Motherboard Replacement: step 2, image 2 of 3 Nest Cam Motherboard Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
    Ask FixBot
  3. Nest Cam Motherboard Replacement: step 3, image 1 of 2 Nest Cam Motherboard Replacement: step 3, image 2 of 2
    • Remove the two 4 mm screws with the JIS 000 screwdriver from the center.
    • Disconnect the black Wi-Fi cable from the motherboard with the tweezers.
    Ask FixBot
  4. Nest Cam Motherboard Replacement: step 4, image 1 of 3 Nest Cam Motherboard Replacement: step 4, image 2 of 3 Nest Cam Motherboard Replacement: step 4, image 3 of 3
    • Use a plastic spudger to lift the motherboard slightly up to expose and disconnect the white cable and the yellow/white IR cable with tweezers.
    • Then use the spudger or a finger to lift the motherboard completely up and off.
    • When installing the new motherboard ensure that all wires are reconnected before securing.
    Ask FixBot
5 other people completed this guide.
Khiry Jones
159 Reputation
1 Guide authored
USF Tampa, Team 1-1, Leahy Spring 2016 Member of USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
7 Members
10 Guides authored
4 Guide Comments
where can I get a MoBo for my drop cam?
mikelebp1 - Reply Share
where can i find a motherboard replacement?
Steve - Reply Share
I have a Nest Outdoor IQ Camera. The Camera is Dead. Would love to Replace the Motherboard. Where can I get one ???
pmwenc@aol.com - Reply Share
same here, no where to be found online
chantalder - Reply Share
Past 24 Hours: 5
Past 7 Days: 10
Past 30 Days: 49
All Time: 25,648
