Nest Cam IQ Camera Replacement
    1. Nest Cam IQ Camera Replacement, Camera: step 1, image 1 of 1
      • To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
      • Leave the iOpener on the glass lens for two minutes.
      • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
      Ask FixBot
    2. Nest Cam IQ Camera Replacement: step 2, image 1 of 1
      • Use an opening tool to split apart the glass lens from the body.
      • Be careful to not break the glass when prying from the body.
      Ask FixBot
    3. Nest Cam IQ Camera Replacement: step 3, image 1 of 1
      • Place a suction cup on the glass lens that you heated up with the iOpener.
      • Press down on the suction cup to create a seal, and pull up with force to create a separation between the glass lens and the body.
      • Pull off the glass lens using the suction cup.
      Ask FixBot
    4. Nest Cam IQ Camera Replacement: step 4, image 1 of 2 Nest Cam IQ Camera Replacement: step 4, image 2 of 2
      • Carefully disconnect the flat black ribbon cable connecting the metal plate to the LED.
      • Remove the metal plate.
      Ask FixBot
    5. Nest Cam IQ Camera Replacement: step 5, image 1 of 2 Nest Cam IQ Camera Replacement: step 5, image 2 of 2
      • Remove the five 9 mm TR6 Torx screws from the LED cover.
      • Pull off the LED cover.
      • As you remove the LED cover, be careful not to tear the flat black ribbon connecting the LED to the motherboard.
      Ask FixBot
    6. Nest Cam IQ Camera Replacement: step 6, image 1 of 3 Nest Cam IQ Camera Replacement: step 6, image 2 of 3 Nest Cam IQ Camera Replacement: step 6, image 3 of 3
      • Carefully disconnect the flat black ribbon cable connecting the LED to the motherboard.
      • Remove the LED cover.
      Ask FixBot
    7. Nest Cam IQ Camera Replacement: step 7, image 1 of 1
      • Remove the two 7 mm TR6 Torx screws securing the camera.
      • Carefully pull out the camera.
      • As you remove the camera, be careful not to tear the flat black ribbon connecting the camera to the motherboard.
      Ask FixBot
    8. Nest Cam IQ Camera Replacement: step 8, image 1 of 2 Nest Cam IQ Camera Replacement: step 8, image 2 of 2
      • Carefully disconnect the flat black ribbon cable connecting the camera to the motherboard.
      • Remove the camera.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 23
All Time: 769
