This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Nespresso coffee maker (Invensys) water pump test
View statistics:
Past 24 Hours:
3
Past 7 Days:
29
Past 30 Days:
56
All Time:
56
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
    1. Nespresso coffee maker (Invensys) water pump test, Nespresso coffee maker (Invensys) water pump test: step 1, image 1 of 3 Nespresso coffee maker (Invensys) water pump test, Nespresso coffee maker (Invensys) water pump test: step 1, image 2 of 3 Nespresso coffee maker (Invensys) water pump test, Nespresso coffee maker (Invensys) water pump test: step 1, image 3 of 3
      • Water pump; in this document, we see it removed from the machine, but both outside and inside the coffee maker, we can test the water pump by powering it directly with a cable and 2 faston connectors, which is the first and most basic thing we have to check before powering it.
      • It is to verify that the pump operates at 230 V AC (voltage in Europe); in other countries, you have 110 V. This is indicated on the sticker on the housing.
      Ask FixBot
    2. Nespresso coffee maker (Invensys) water pump test: step 2, image 1 of 3 Nespresso coffee maker (Invensys) water pump test: step 2, image 2 of 3 Nespresso coffee maker (Invensys) water pump test: step 2, image 3 of 3
      • We can check the pump coil with a multimeter on the ohms scale, starting at the 2M scale in one direction and then in the other direction; keep in mind that some water pumps have a thermal fuse in series with the winding. This fuse is generally visible; if you don't see it, it means there is no fuse and it is a simple coil.
      • Checking that the multimeter is working: The first thing we will do is, on the 2M ohms scale, touch the multimeter's test probes together to check that it measures 000.
      • Once this is done, we will check one of the two polarities (black on the left, red on the right). If the multimeter does not measure anything, we will proceed to check it the other way around.
      • The one in the example is faulty; it does not report any electrical resistance in the measurement.
      Ask FixBot
    3. Nespresso coffee maker (Invensys) water pump test: step 3, image 1 of 3 Nespresso coffee maker (Invensys) water pump test: step 3, image 2 of 3 Nespresso coffee maker (Invensys) water pump test: step 3, image 3 of 3
      • Multimeter scale 2 M = 2,000,000 ohms full scale.
      • Just in case, we will also check the measurement on the 20 M scale. In this case, the pump is broken; it has a burnt-out, open coil, which is why it does not measure in either direction. It should be remembered that some water pumps have a thermal fuse directly attached to one of the poles; this specific model does not have one.
      • Other Nespresso guides: Nespresso
      Ask FixBot
Finish Line
Carlos López (España - Spain)
106,448 Reputation
391 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 56
All Time: 56
