Nespresso Vertuo Next Water Pump Replacement
  1. Nespresso Vertuo Next Water Pump Replacement, Water Pump: step 1, image 1 of 3 Nespresso Vertuo Next Water Pump Replacement, Water Pump: step 1, image 2 of 3 Nespresso Vertuo Next Water Pump Replacement, Water Pump: step 1, image 3 of 3
    • Insert an opening tool in the seams between the rear panel and chassis.
    • Pry off the rear panel.
    • You may need multiple opening tools at once in order to open the device panel.
    Ask FixBot
  2. Nespresso Vertuo Next Water Pump Replacement: step 2, image 1 of 3 Nespresso Vertuo Next Water Pump Replacement: step 2, image 2 of 3 Nespresso Vertuo Next Water Pump Replacement: step 2, image 3 of 3
    • Remove the four 13.5 mm screws on the base plate using a T18 Torx screwdriver.
    Ask FixBot
  3. Nespresso Vertuo Next Water Pump Replacement: step 3, image 1 of 3 Nespresso Vertuo Next Water Pump Replacement: step 3, image 2 of 3 Nespresso Vertuo Next Water Pump Replacement: step 3, image 3 of 3
    • With tweezers, pinch one half of each connected pair of wires, and then gently pull and disconnect the wires.
    • Use a pair of tweezers to clamp down and disconnect the water line connecting to the base plate of the machine.
    • Remove the base plate from device
    • Wires can be fragile, handle with care.
    Ask FixBot
  4. Nespresso Vertuo Next Water Pump Replacement: step 4, image 1 of 3 Nespresso Vertuo Next Water Pump Replacement: step 4, image 2 of 3 Nespresso Vertuo Next Water Pump Replacement: step 4, image 3 of 3
    • Remove the rubber hoop connecting the motor to the base.
    • Lift the motor off of baseplate and pull waterline away from the base.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Philip_S
431 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 38
Past 30 Days: 198
All Time: 2,556
