Nespresso Vertuo Next Upper Water Line Replacement
  1. Nespresso Vertuo Next Upper Water Line Replacement, Power Button: step 1, image 1 of 2 Nespresso Vertuo Next Upper Water Line Replacement, Power Button: step 1, image 2 of 2
    • Side an opening tool in between where the top cover meets the white head piece and apply force to push the cover off.
    • Remove the cover from the device.
    Ask FixBot
  2. Nespresso Vertuo Next Upper Water Line Replacement: step 2, image 1 of 2 Nespresso Vertuo Next Upper Water Line Replacement: step 2, image 2 of 2
    • Use a T19 Torx screwdriver to remove the white top cover of the machine.
    • While pulling away the top cover, ensure that you don't pull out any wires or other parts.
    Ask FixBot
  3. Nespresso Vertuo Next Upper Water Line Replacement: step 3, image 1 of 2 Nespresso Vertuo Next Upper Water Line Replacement: step 3, image 2 of 2
    • Pop out the power button by pressing your thumb on the button and pressing down.
    Ask FixBot
  4. Nespresso Vertuo Next Upper Water Line Replacement: step 4, image 1 of 2 Nespresso Vertuo Next Upper Water Line Replacement: step 4, image 2 of 2
    • Use tweezers to unplug the wires from the power button.
    • Apply slight force and carefully pull the wire out as to not damage any pins.
    Ask FixBot
  5. Nespresso Vertuo Next Upper Water Line Replacement, Upper Water Line: step 5, image 1 of 2 Nespresso Vertuo Next Upper Water Line Replacement, Upper Water Line: step 5, image 2 of 2
    • Use tweezers to remove the clip at the end of the upper water line.
    • Note: You may have to grasp with your other hand and pull the line with your other in order to remove the clip.
    Ask FixBot
  6. Nespresso Vertuo Next Upper Water Line Replacement: step 6, image 1 of 2 Nespresso Vertuo Next Upper Water Line Replacement: step 6, image 2 of 2
    • For the second clip on the lower part of the line, repeat the previous step. After the removal of the second clip, the remove the line.
    Ask FixBot
Tyler Nunes
88 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 95
All Time: 1,262
