Nespresso Vertuo Next Power Cord Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
124
All Time:
1,181
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide if you have a damaged or malfunctioning power cord in your Nespresso Vertuo Next. The power cord is what connects the machine to a direct power source such as your home outlets. Without this cord, your machine may not stay on or power on at all.
Before you remove and replace your power cord. Check to ensure that the outlet or power source that you are using is not the culprit. Try moving the device to another outlet, or test a different electronic device with the same outlet, to see if voltage is being generated by it. If the power source is not the problem then a problem is most likely occurring with your power cord and should be replaced Before replacing, make sure the device is fully unplugged.
Tools
    1. Nespresso Vertuo Next Power Cord Replacement, Water Pump: step 1, image 1 of 3 Nespresso Vertuo Next Power Cord Replacement, Water Pump: step 1, image 2 of 3 Nespresso Vertuo Next Power Cord Replacement, Water Pump: step 1, image 3 of 3
      • Insert an opening tool in the seams between the rear panel and chassis.
      • Pry off the rear panel.
      • You may need multiple opening tools at once in order to open the device panel.
      Ask FixBot
    2. Nespresso Vertuo Next Power Cord Replacement: step 2, image 1 of 3 Nespresso Vertuo Next Power Cord Replacement: step 2, image 2 of 3 Nespresso Vertuo Next Power Cord Replacement: step 2, image 3 of 3
      • Remove the four 13.5 mm screws on the base plate using a T18 Torx screwdriver.
      Ask FixBot
    3. Nespresso Vertuo Next Power Cord Replacement: step 3, image 1 of 3 Nespresso Vertuo Next Power Cord Replacement: step 3, image 2 of 3 Nespresso Vertuo Next Power Cord Replacement: step 3, image 3 of 3
      • With tweezers, pinch one half of each connected pair of wires, and then gently pull and disconnect the wires.
      • Use a pair of tweezers to clamp down and disconnect the water line connecting to the base plate of the machine.
      • Remove the base plate from device
      • Wires can be fragile, handle with care.
      Ask FixBot
    4. Nespresso Vertuo Next Power Cord Replacement: step 4, image 1 of 3 Nespresso Vertuo Next Power Cord Replacement: step 4, image 2 of 3 Nespresso Vertuo Next Power Cord Replacement: step 4, image 3 of 3
      • Remove the rubber hoop connecting the motor to the base.
      • Lift the motor off of baseplate and pull waterline away from the base.
      Ask FixBot
    1. Nespresso Vertuo Next Power Cord Replacement, Power Cord: step 5, image 1 of 3 Nespresso Vertuo Next Power Cord Replacement, Power Cord: step 5, image 2 of 3 Nespresso Vertuo Next Power Cord Replacement, Power Cord: step 5, image 3 of 3
      • Use needle nose plies to remove the panel.
      • Turn base plate over and remove the plastic piece that held the power cord's wires.
      Ask FixBot
    2. Nespresso Vertuo Next Power Cord Replacement: step 6, image 1 of 3 Nespresso Vertuo Next Power Cord Replacement: step 6, image 2 of 3 Nespresso Vertuo Next Power Cord Replacement: step 6, image 3 of 3
      • Pull wires and power cord out through the bottom of the base plate.
      • Pull one wire out at a time to avoid any damage.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Lucas Pimentel
91 Reputation
1 Guide authored
1 Guide Comment
It is impossible to remove the rear panel if you don't remove the base plate as the 2 back screws are holding the panel.
Baptiste VALLET - Reply Share
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 124
All Time: 1,181
