Nespresso U inner coffee spout replacement
  1. Nespresso U inner coffee spout replacement, Internal coffee spout: step 1, image 1 of 2 Nespresso U inner coffee spout replacement, Internal coffee spout: step 1, image 2 of 2
    • Insert an opening tool into the gap between the coffee spout and the side panel on the right side. Push the side panel away a few millimeters and push the tool down until the side panel at the front edge comes loose with a loud crack
    • Repeat on the left side.
    Ask FixBot
  2. Nespresso U inner coffee spout replacement: step 2, image 1 of 2 Nespresso U inner coffee spout replacement: step 2, image 2 of 2
    • Push the side parts apart at the top.
    • Lift out the coffee spout, it is held in place by detents.
    Ask FixBot
  3. Nespresso U inner coffee spout replacement: step 3, image 1 of 1
    • Plug in the connector and turn on the machine.
    • Push the slider for the capsule forward until the motor moves the brewing unit forward, when it is half way, then gently push the slider back so that the brewing unit stops half way.
    • Pull the power plug.
    Ask FixBot
  4. Nespresso U inner coffee spout replacement: step 4, image 1 of 2 Nespresso U inner coffee spout replacement: step 4, image 2 of 2
    • Now you can lift out the defective inner coffee spout. Its retaining tabs are probably broken off, so this should be quite easy.
    Ask FixBot
  5. Nespresso U inner coffee spout replacement: step 5, image 1 of 2 Nespresso U inner coffee spout replacement: step 5, image 2 of 2
    • The two broken tabs are clearly visible. In the second picture, the old and the new part are next to each other.
    Ask FixBot
  6. Nespresso U inner coffee spout replacement: step 6, image 1 of 2 Nespresso U inner coffee spout replacement: step 6, image 2 of 2
    • Take the opportunity to clean the spout rocker and all internal parts.
    Ask FixBot
  7. Nespresso U inner coffee spout replacement: step 7, image 1 of 1
    • Press firmly on the new coffee spout.
    Ask FixBot
  8. Nespresso U inner coffee spout replacement: step 8, image 1 of 3 Nespresso U inner coffee spout replacement: step 8, image 2 of 3 Nespresso U inner coffee spout replacement: step 8, image 3 of 3
    • The broken upper flap is still present here. Lift it out with tweezers.
    Ask FixBot
Work through the steps in reverse order to reassemble your device.
7 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
335,961 Reputation
311 Guides authored
4 Guide Comments
Estos pasos que me indica ya los he realizado lo que ahora necesito es seguir desmontando la máquina para acceder a la parte movible que prensa la cápsula, para poder actuar a ese nivel y proder a la limpieza profunda de todo el conjunto
Gracias y espero que me pueda orientar para el desmlntaje completo de la máquina
losdo85 - Reply Share
I have already carried out these steps that you indicate, what I now need is to continue disassembling the machine to access the movable part that presses the capsule, to be able to act at that level and proceed to deep clean the entire assembly.
Thank you and I hope you can guide me for the complete dismantling of the machine
Sorry - to date, I have not had to open this machine any further. But maybe these instructions do help you: Nespresso CitiZ Brewing Unit replace
VauWeh - Reply Share
Wo bekomme das Teil für den König 10133?
mbi - Reply Share
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 170
All Time: 7,340
