Nespresso Essenza Mini Coffee Machine Button Board Replacement
    1. Nespresso Essenza Mini Coffee Machine Button Board Replacement, Button Board: step 1, image 1 of 1
      • Remove the water tank.
      Ask FixBot
    2. Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 2, image 1 of 3 Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 2, image 2 of 3 Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 2, image 3 of 3
      • Locate the panel on the bottom of the machine.
      • Unscrew both screws with a T10 star head screwdriver.
      Ask FixBot
    3. Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 3, image 1 of 3 Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 3, image 2 of 3 Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 3, image 3 of 3
      • Remove the cover to reveal the inside of the machine.
      Ask FixBot
    4. Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 4, image 1 of 3 Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 4, image 2 of 3 Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 4, image 3 of 3
      • Push the plastic pry tool into the release tabs located on the bottom of the machine.
      • Remove the cover.
      Ask FixBot
    5. Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 5, image 1 of 2 Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 5, image 2 of 2
      • Use the plastic pry tool again to push into the release tabs on the sides and the top of the machine.
      • Remove the cover to expose the pump and the inner electrical parts.
      Ask FixBot
    6. Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 6, image 1 of 2 Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 6, image 2 of 2
      • Locate the main electrical board as seen in the image.
      • Gently pull the electrical board out of the machine.
      Ask FixBot
    7. Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 7, image 1 of 3 Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 7, image 2 of 3 Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 7, image 3 of 3
      • Locate the buttons on the machine.
      • Remove the button cover to expose the actual button board.
      Ask FixBot
    8. Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 8, image 1 of 2 Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 8, image 2 of 2
      • Use the plastic pry tool to push the two locking tabs inside the machine, releasing the button board.
      • Remove the button board from inside of the machine.
      Ask FixBot
    9. Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 9, image 1 of 2 Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 9, image 2 of 2
      • Fit a new button board into place of the old button board.
      Ask FixBot
    10. Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 10, image 1 of 2 Nespresso Essenza Mini Coffee Machine Button Board Replacement: step 10, image 2 of 2
      • Connect the wire from the energy box to the new button board.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
RLinvill
181 Reputation
1 Guide authored
UC Davis, Team 3-8, Whithaus Spring 2025 Member of UC Davis, Team 3-8, Whithaus Spring 2025
UCD-WHITHAUS-S25S3G8
2 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 34
Past 30 Days: 147
All Time: 1,621
