Up to 20% off select tools
Nerf Vortex Vigilon Slide Replacement
Views: 3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
95
All Time:
3,036
Comments: 2
2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
In two steps, this guide will show you how to remove the slide pieces with a screwdriver so that they can be replaced.
    1. Nerf Vortex Vigilon Slide Replacement, Removing the slide screws: step 1, image 1 of 1
      • The two slide pieces hold the orange sight in place. Expect that the sight will come off when you remove the slide pieces.
      • Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
      • Both sides of the slide will come off when the screws are removed.
      Ask FixBot
    2. Nerf Vortex Vigilon Slide Replacement, Removing the slide pieces: step 2, image 1 of 1
      • Lift both slide pieces off of the gun.
      Ask FixBot
2 other people completed this guide.
Author
with
Cara Pew
932 Reputation
7 Guides authored
Cal Poly, Team 13-6, Forte Fall 2014 Member of Cal Poly, Team 13-6, Forte Fall 2014
CPSU-FORTE-F14S13G6
5 Members
84 Guides authored
2 Guide Comments
Ok so the slide is removed now what? It's still stuck
amanintights1981 - Reply Share
i was thinking the same thing
Christina TheTurtle - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 95
All Time: 3,036
