Up to 20% off select tools
Nerf Vortex Vigilon Loading Spring Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
104
All Time:
2,255
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
You will only need a screwdriver to take apart this Nerf gun and access the loading spring. Also obtain a new spring if needed.
    1. Nerf Vortex Vigilon Loading Spring Replacement, Removing the slide screws: step 1, image 1 of 1
      • The two slide pieces hold the orange sight in place. Expect that the sight will come off when you remove the slide pieces.
      • Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
      • Both sides of the slide will come off when the screws are removed.
      Ask FixBot
    2. Nerf Vortex Vigilon Loading Spring Replacement, Removing the slide pieces: step 2, image 1 of 1
      • Lift both slide pieces off of the gun.
      Ask FixBot
    1. Nerf Vortex Vigilon Loading Spring Replacement, Removing the outer screws: step 3, image 1 of 2 Nerf Vortex Vigilon Loading Spring Replacement, Removing the outer screws: step 3, image 2 of 2
      • Remove the twelve #00 1 cm Phillips screws.
      • Because the holes for the screws are deeper than the screw size, some of the screws may not come out even after you have completely unscrewed them. They will come out when you take off the outside cover in the next step, which is okay.
      • Rotate the gun so that the front is facing you to remove the final screw.
      Ask FixBot
    2. Nerf Vortex Vigilon Loading Spring Replacement, Removing the outside cover: step 4, image 1 of 1
      • When removing the cover, the clip attachment and the spring will likely fall out of the gun.
      • Lift the outside cover off of the gun. Only the side where you removed the screws will come off.
      • The magazine will slide down automatically as you remove the cover.
      Ask FixBot
    1. Nerf Vortex Vigilon Loading Spring Replacement, Removing the spring: step 5, image 1 of 2 Nerf Vortex Vigilon Loading Spring Replacement, Removing the spring: step 5, image 2 of 2
      • Lift the spring out towards you.
      Ask FixBot
Author
with
Cara Pew
932 Reputation
7 Guides authored
Cal Poly, Team 13-6, Forte Fall 2014 Member of Cal Poly, Team 13-6, Forte Fall 2014
CPSU-FORTE-F14S13G6
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 104
All Time: 2,255
