Nerf Recon CS-6 Trigger Replacement
Views: 4.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
99
All Time:
4,627
Comments: 4
4 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Nerf Recon CS-6 Trigger Replacement, Remove Magazine: step 1, image 1 of 1
      • Skip this step if magazine is already removed.
      • Pull slide back.
      • Pull backwards on release buttons and slide magazine out.
      • Push slide back forward and pull trigger.
      Ask FixBot
    2. Nerf Recon CS-6 Trigger Replacement, Remove Visible Screws: step 2, image 1 of 1
      • Use the Phillips #0 Screwdriver to remove these 9 screws.
      • All screws marked in red are 9.6 mm Phillips #0 screws.
      • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
      Ask FixBot
    3. Nerf Recon CS-6 Trigger Replacement, Remove Hidden Screws: step 3, image 1 of 2 Nerf Recon CS-6 Trigger Replacement, Remove Hidden Screws: step 3, image 2 of 2
      • Pull slide back to reveal more screws.
      • Remove these 2 screws.
      • Push slide forward.
      • Pull trigger to release compression of the main spring.
      • Screws are 9.6 mm Phillips #0.
      • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
      Ask FixBot
    4. Nerf Recon CS-6 Trigger Replacement, Remove Plunger Cap: step 4, image 1 of 1
      • Remove the screws on the plunger cap.
      • Tug the plunger cap off.
      Ask FixBot
    5. Nerf Recon CS-6 Trigger Replacement, Remove Slide Screws: step 5, image 1 of 1
      • Remove the 2 screws on the slide.
      • Hold the two halves of the gun together to prevent any springs from launching out.
      Ask FixBot
    6. Nerf Recon CS-6 Trigger Replacement, Split the Gun in Half: step 6, image 1 of 2 Nerf Recon CS-6 Trigger Replacement, Split the Gun in Half: step 6, image 2 of 2
      • Pull the gun apart at the middle seam.
      • Watch for any springs that might launch out.
      Ask FixBot
    1. Nerf Recon CS-6 Trigger Replacement, Remove Trigger: step 7, image 1 of 1
      • Lift trigger up out of the gun.
      • From here, the trigger or the trigger spring can be replaced.
      Ask FixBot
Pam Ruffner
1,002 Reputation
3 Guides authored
Baylor, Team 8-14, Williams Fall 2014 Member of Baylor, Team 8-14, Williams Fall 2014
BU-WILLIAMS-F14S8G14
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 99
All Time: 4,627
