Introduction
The Nerf N-Strike Mega Cycloneshock is among the most famous Nerfs on the market. Over time, the plunger spring may weaken, reducing the blaster's performance. Replacing the plunger spring can restore or even enhance the firing power. This guide will walk you through the step-by-step process of replacing the plunger spring.
Remove all 12 screws with Phillips #1 screwdriver. Keep them in a small container to prevent loss.
Carefully pry the primer off.
By following this guide, you have successfully replaced the plunger spring in your Nerf N-Strike Mega Cycloneshock. This simple upgrade can restore and ensure stronger and more consistent shots, and if you experience any issues, double check the alignment of internal components.
